16 pin BSM connector C5 2004
Results 1 to 3 of 3
    Mar 2013
    israel
    71
    Default 16 pin BSM connector C5 2004
    hellow
    the cables to the fan motor blower in the 16 connector pin to BSM has burnet and melt the connector.
    how and where can i buy this connector or the entire loom?
    I KNOW ITS A SIEMENS a3 BSM and its 16 pin special connector ?
    is there a part number anywhere?
    thank all!!!
    9,769
    There is actually a connector catalogue as part of Citroen Service, but you could probably find something used from a wrecked car and make a repair. If the metal of the connector is damaged, then the problem will happen again. In that case, you might be better off replacing the BSM and splicing in a new wire and/or plug. If that's not possible, then try to run a new wire as a bypass.
    Mar 2013
    israel
    71
    Default thanks mate
    thanks for the info!
