Buying a C4 VTS....any tips?
Results 1 to 19 of 19
Like Tree3Likes
Thread: Buying a C4 VTS....any tips?
    brisbane
    2,924
    Default Buying a C4 VTS....any tips?
    As above really.... just wanting to know all the hiccups with these cars before possible purchase.
    Its a 2007 [was there any updates? ] and has 111,000 k's...pano roof option.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    10,188
    They were pretty good cars, but became slow sellers. So, there can be an appreciable difference between the build (look in the boot) and compliance dates.
    The usual used car checks apply and there are few nasty surprises other than the cost of new wipers if you are used to the $5 refill variety. One particularly costly issue (if you decide it MUST work!) is failure of the seat heaters as the pad is embedded in the foam/trim sandwich. You can sometimes repair the wire at the bottom by digging in to find the break. At the other end of the cost scale, a knock at the back over bumps may simply be the bump stop on the shock absorber falling down.
    It will probably have HID headlamps, which are excellent, but also expensive to replace. Check they operate and are look to be the correct white with a blue hue. Pinkish suggests old and failing.
    You have the common to many PSA models Comm unit to check. Failure to cancel after a turn suggests it's on it's way out.
    ABS/Airbag faults are usually due to either a bad brake switch or a break in the wire at a seatbelt buckle.
    Make sure the cruise control works. It's a separate switch assembly on the steering hub. With earlier models, the thumbwheel contacts can sometimes corrode, so you run it back and forward 30 times, which might correct the problem for free.
    The cooling system can be a slightly weak point. Look for signs of leakage and check the water pump for leakage and noise. Some people will disconnect the heater core to fix leakage that is most likely due to two o-rings. If it's at 111K, the pump is likely to have been replaced with a timing belt job, but the original plastic bodied pump didn't last as well as the aluminium variety.
    If the glass roof is still in one piece (look for cracks), it may now stay that way, but you need to ensure your insurance will cover the glass roof replacement as they cost thousands.
    Look down the sides of the windscreen for little bubbles, which can suggest it is beginning to delaminate. It may stay like that for a long time, but it can be a bargaining point. Be aware that the bottom of the screen is slightly overhanging, so don't lean on it. The scuttle air intake also tends to slip off the bottom of the windscreen and should not be left like that.
    brisbane
    2,924
    Great tips there David....much appreciated :}
    I got a bit worried when the seller immediately dropped the price from $7.5k to $5.750 to get a sale. Mmmmm. ;]
    It is in very good condition however it may be too good to be true at that price if you know what i mean
    jr20516v
    Now:
    10,188
    There could be many reasons for a cut-price sale from a seriously defective car, something fishy in the title/history to simply needing a prompt sale. Do the appropriate checks for theft, w/off, debts etc. and perhaps have a look at it if it still seems OK. If you are worried about some aspect of the car either walk away or have it inspected. Could it be just about due for tyres, brakes, rego, timing belt, clutch plus a major service??? You might win the Quinella or Trifecta!
    Feb 2013
    456
    Check the UK C4owners forum for more info. I still think they are one of the best looking modern CitroŽn's so far.
    brisbane
    2,924
    Nah !! I have purchased many scores of cars over the years so mostly know all the tricks. Everything seems in order with the car...good tyres etc etc however i cant really check the Comms 2000 as it may play up after many weeks [My Berlingo can go weeks without a hiccup ] and not on the test drive day.
    It is not a private sale....it is a Mercedes dealer.
    jr20516v
    Now:
    Sep 2003
    North Parramatta
    4,024
    There is Series I and II versions, but I don't think the Series II VTS was ever sold here.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Feb 2013
    456
    The 2 door can have problems with the rear hatch wiring harness effecting the locking etc yet it could even have been replaced by now? Otherwise the specific wiper blades can be sourced via eBay very reasonably.
    10,188
    Quote Originally Posted by jr20516v View Post
    Which could mean they took it as a trade for more than any wholesaler would offer and thought they'd have a go themselves, but have now decided to quit it. It's probably OK, just not the sort of car that dealer wants to keep. Friends bought one new and it's turned out to be an excellent car for them ... well apart from the depreciation aspect!
    Feb 2011
    christmas hills
    10
    Default C4 vts
    I have a 2007, 1st Reg 2/09 VTS, bought @ 40k, now 65, great car, no problem, joy to drive. At that time I saw them for 11 up to 15k for 50-105K!! Mine had been traded at a Toyota dealer, they could not get rid of it, asking 13500 originally, I paid 9k. All the opp'l extras too. V poor resale, nobody knows what they are. I did. Happy man. Good luck, 110k looks a bit old , there's one on Gumtree for 10k, only 50km. Worth 7.5 I reckon.
    brisbane
    2,924
    Exactly what i was thinking too David.
    jr20516v
    Now:
    brisbane
    2,924
    I have conflicting info on cambelt changes on the C4 2007 VTS.....some say every 80k and then other info says every 105k.
    I would guess its the former.....yes/no?
    jr20516v
    Now:
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,876
    Or 4 years. Change it.
    Easy enough motor to do the belt/pump.
    brisbane
    2,924
    Any answer to post #12 guys ? Unfortunately saying "every 4 years" is not much help when the car is 7 years old........either its 1 year shy of its next belt change ....OR its bloody 3 years over due.
    jr20516v
    Now:
    brisbane
    2,924
    jr20516v
    Now:
    10,188
    I don't know the standard change interval. Perhaps, refer to the handbook or check with the local dealer? Peugeot often specify a longer period compared to Citroen, even for the same engine. Can you check the history? It will likely have had a water pump (with belt and tensioner) during the warranty period or soon after if the owner was 'lucky' enough to have had one that lasted that long. You could start the count from then if it appears never to have had a timing belt changed otherwise. Don't forget the car may not have been sold in 2007 although it might have been built then.
    May 2002
    canberra...
    8,876
    Very few places will adhere to the time thing... If you don't know when it was last replaced, assume it hasn't been.
    Sep 2003
    North Parramatta
    4,024
    Where on earth did you find the 105k interval? That is odd.
    The Peugeot GTi180 (same motor) has a 80k/4yr interval, according to Peugeot Australia. They choose to use the "severe conditions" schedule.
    I have a feeling CitroŽn Australia might specify 100k/4yrs for all timing belts, but I'm not sure on that one.
    Simon
    brisbane
    2,924
    Yep, Cit specify 100,000K's :}
    jr20516v
    Now:
