C4 coupe boot wont open.
Results 1 to 3 of 3
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    468
    Default C4 coupe boot wont open.
    I have a mate with a C4 Coupe can anyone tell me how i can open the boot
    the latch is unresponsive.
    9,266
    Crawl in from the back seat, and stick a small screwdriver into the hole on the lock. You can push the mechanism to unlock. Once it's open look for the fault. I'd start by peeling back the rubber sleeves on the hatch and checking the wiring.
    Sep 2003
    North Parramatta
    4,025
    A reasonably common failure on PSA cars of this era is the microswitch for the hatch release (item 30 in attached piccy).
    This, of course, doesn't mean it's the problem in this case. The wiring loom can also be damaged near the hinge like seasink has suggested, or maybe some lubrication of the catch is required.
    If you sign up to C4Owners.org there is a thread or two that is similar:
    Forums / C4 The Garage / C4 Hatchback boot won't open - C4 - DS4 Owners
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
