Citroen 1984 CX Gti 2500
Results 1 to 11 of 11
Like Tree2Likes
Thread: Citroen 1984 CX Gti 2500
    Nov 2005
    58
    Default Citroen 1984 CX Gti 2500
    Hi
    My CX is cutting out when the manual gear box is put into reverse. It has a reverse warning system would that be causing the engine to cut out?
    Any suggestions on what could be causing it?
    Herby
    16,753
    the bit of accordion hose between the AFM and inlet manifold. Putting the engine into reverse twists the engine the opposite way, so opens splits in the accordion. You'll need to pull it off to verify.
    Nov 2005
    58
    Thanks Shane. I'll have to explain it to my mechanic who's trying to sort it out.
    He was thinking it was electrical.
    Sorry AFM?
    Herbyj
    16,753
    air flow meter, the bit on top of the air cleaner. The split may not be obvious, you may need to pull the bellows off and bend them to find the breaks. I would have expected this would be the first thing any mechanic would check on any vehicle fitted with an Air Flow Meter.
    The hose is no bargain to buy
    http://cx-basis.de/eshop/product_inf...oducts_id=6577
    OMG ... that's the price for a USED one
    shane L.
    Nov 2005
    58
    Thanks again Shane for all the info.
    I spoke to the mechanic and he's checked all of the hoses carefully and it's not a hose.He says it must be a loose wire somewhere but he's having trouble finding it.
    Fellow Frogger! andrewj's Avatar
    Margate
    395
    Quote Originally Posted by HERBYJ View Post
    The engine temperature sensor is one wire that would kill the engine immediately (flood it) if it is loose. It's on the right hand side near the top of the engine
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    Feb 2006
    Brisbane, QLD, Australia
    515
    That would be one possibility. I have had that problem before add well. And I've had even weirder problem. When putting on reverse and the engine moved it trapped the coil lead between the manifold one the front member cutting through the insulation and shorting out. Sweet.
    Sent from my Nexus 7 using Tapatalk
    CX Register
    16,753
    Did he check every hose and connection between the Air Flow Meter and inlet manifold ? It really does sound exactly like the problem above, I have seen it on a few different CX's. The splits are usually at the bottom where you can't see it unless you pull the hose off and flex the accordion joint in it.
    ie: Did he actually remove this hose to check !! Just looking isn't good enough
    shane L.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Or get the engine idling and squish and flex that hose. Then you will know for sure
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Nov 2005
    58
    I just heard from the mechanic. He's fixed it and it was a broken wire, I'm not sure where.
    Thanks to everyone for the replies.
    16,753
    I'd be interested to know which. The wiring should be big plugs off the back of the engine. If one is dodgy ......... they all need replacing!
