DS clutch pedal
Results 1 to 8 of 8
Thread: DS clutch pedal
    Mar 2011
    Ireland
    147
    Default DS clutch pedal
    Hi all
    The clutch pedal on my DS23 5 speed doesn't come up fully when I take my foot off, it can be pulled up by my foot and stays up. When depressed there is no resistance until it's halfway down. Gear changes are fine with no crunching. Is it a case of simple adjustment or something more serious?
    Ed
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,412
    Check the two cable ends for fraying. You might need a new cable.
    Roger
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Another item to check is the position of the over centre spring on the clutch pedal itself!
    Cheers Gerry
    Fellow Frogger! k eeles's Avatar
    Jul 2005
    Buderim
    142
    Good morning SilverBullet. When my D Special started this caper it needed a new clutch pivot assembly.
    Fellow Frogger! renault12's Avatar
    Sep 2005
    Sydney, Australia
    430
    Quote Originally Posted by k eeles View Post
    Me too. The pivot snapped 100km later, leaving me spectacularly stranded for the first time with my D.
    Caution..
    3,166
    Quote Originally Posted by renault12 View Post
    Caution..
    Those pivots are he weakest link on a late RHD D series manual car. Can't you just hear Cornelia Francis now? "You are the Weakest Link -----Good-Bye"
    Cheers Gerry
    skp
    skp is offline
    218
    Clutch pedal return spring has broken. Not an earth shattering drama, but annoying.
    You need to remove the pedal assembly ( easy ) and replace this strong spring. As it is a late DS, there is a weak secondary spring that works on a small hook, but it is the one wound around the pivot shaft that you need to attend to.
    skp
    Mar 2011
    Ireland
    147
    Hi, the pivot is new, replaced last year, and at that time the cable was in good condition, no fraying. Car has only driven about 2000km since then. This new issue has been gradual, pedal was fine, then returned most if the time, now it never comes all the way up on its own. I will check the springs on the pedal assembly.
    Ed
