1985CX gti oil filter....
Results 1 to 11 of 11
Thread: 1985CX gti oil filter....
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default 1985CX gti oil filter....
    Does anybody know where this is...
    Don't remind me!
    16,609
    On the motor, or where to buy one?
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    found it. This is going to be interesting....
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Best to work from underneath with the car on ramps or, ideally on a hoist!
    Cheers Gerry
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    On ramps with the car on maximum height. This so you will have some room to move your arms around. I use a filter wrench made from seat belt webbing. You need a long extension and put it up the drivers side gap, just loosen and then your hand up the passengers side gap with a rag to catch oil and then unscrew. If you can catch all the oil, i.e. don't spill any buy yourself a lottery ticket.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    CitroŽn Tragic UFO's Avatar
    9,810
    Once you get the car on the ramps on maximum height (hint do not try to drive it onto the ramps on max height but one notch below) allow the engine and exhaust to cool for a while - unless you have asbestos forearms. Put the car on high once on the ramps.
    16,753
    easiest filter of the lot to change.... Put the car up on ramps, roll under, and using one of those contracting 3legged 3/8th .......... something like this:
    Kincrome 2 WAY 3 JAW OIL Filter Remover Wrench Tool Removal Engine NEW K080004 | eBay
    then use a few long extension bars and feed it up and unscrew the filter. Simple
    Fellow Frogger! andrewj's Avatar
    Margate
    395
    Screwdriver and a hammer. Not elegant, but very effective.
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,082
    The oil filters with the hex shape welded on the bottom are even easier - but I havn't seen one like that for a long time. I must change the oil on my wagon sometime - its been so long that I have almost forgotten how.
    Ken W
    11,304
    Quote Originally Posted by Ken W View Post
    Ken W
    For little driven cars, I do an oil change every Christmas regardless of distance, then I can't forget when it last happened.
    I confess to paying for a BX filter change along with a timing belt job - I'm still puzzled about how to get in to it.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    3,166
    How you refit the filter is very important. If you want to remove it easily next time then do not over tighten the filter. Lubricate the rubber ring gasket with fresh engine oil. Then spin the filter on by hand until the gasket contacts the sealing face of the filter housing. Then turn it by hand for a further 2/3 of a turn and no more! It will not come loose and you will be able to remove it easily next time!
    Cheers Gerry
