Location of BX temperature gauge
Results 1 to 7 of 7
    Member twistedeez's Avatar
    Mar 2011
    Byron Bay
    114
    Default Location of BX temperature gauge
    I have a 1989 TRI. The temp gauge on the dash is not working. I have located the sensors on the back of the motor and also two on part of the heater unit under the distributor. Of these second two one has a blue connection and one has a black connection. The car has aircond and the oil temp gauge.
    What I want to know is which one actually serves the temp gauge??
    Do they simply stop working??
    Could it be another cause considering no-one has been jiggering around with the dash gauges??
    Out of the 1992 Saab 900 turbo and into
    1989 Citroen Bx 16v
    canberra
    300
    AFAIK The standard TRi didn't ever have a temperature gauge. Its most likely you have 16v instruments..
    I have the same and have wired everything from the instruments..I just need to get in and connect these wires to the engine.
    There should be 2 warning light temp sensors ..one for "very hot" ..one for "its too late"..choose one and replace it with a temperature gauge sender..Quite a few should be compatible (pug/other cits)
    CitroŽn Tragic UFO's Avatar
    9,809
    I recall that my BX TRi had a temp gauge. I remember watching it whilst travelling to SA in February one year when the outside temp was near 45 degrees.
    Mar 2011
    Byron Bay
    114
    Yes mine has a gauge. From the factory. Must have been the luxury model. But which sensor is it? Four to choose from. So far the blue one's in the lead.....
    1989 Citroen Bx 16v
    Don't remind me!
    16,609
    On my '90Mi16 the dash gauge's sender plug is blue.
    SMM
    SMM is offline
    Dec 2010
    113
    Gosh, I am feeling ripped off, by old BX didn't have a temperature gauge, just a warning light
    SMM
    Current Citroen - : 2012 C5 HDi Exclusive; C4 Cactus (Mrs SMM)
    Previous Citroens: 1997 Xm Exclusive Series II, 2007 C4 VTR, 2006 C5, 1991 Xm Series 1, 1999 Xsara 1.8, 1988 Bx TRI
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    417
    You may have had a TRS I suspect.
    Via the aussiefrogs App
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
