pressure regulator
Results 1 to 3 of 3
Thread: pressure regulator
    geelong
    71
    Default pressure regulator
    Hi,
    anyone knows witch way this little spring cup goes.pressure regulator-img_2020.jpg
    It is part of pressure regulator.
    Symar/ca/usa
    607
    Quote Originally Posted by adjole View Post
    Hi,
    anyone knows witch way this little spring cup goes.Click image for larger version.
    The face showing in the picture goes against the regulator body. The indentation allows for movement of the regulators 'pilot' slide valve. The opposite side is the spring bearing side. Also remember to place the adjustment shims into the bottom of the overflow cap/cup. Those shims control the 'cut-in' pressure.
    geelong
    71
    thanks alot
