Citroen C5 X7 Hydarulic Pump leak
    Aug 2005
    Merimbula, NSW, Australia
    323
    Default Citroen C5 X7 Hydarulic Pump leak
    Hi,
    I have a 2008 Citroen C5 X7 with a leaky hydraulic pump.
    The LDS will leak out of the pump even without the pump operating.
    I appears to be coming out close to the top of the pump, just below the reservoir.
    After it has been running, the filler cap releases pressure when opened, so it's not likely to be a damaged reservoir.
    Are these repairable?
    Any tips that I should be aware of before I investigate it further?
    Thanks.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    CitroŽn Tragic UFO's Avatar
    9,809
    At the last service of mine a new LDS reservoir cap was fitted as this is a new style that vents. Apparently this factory approved modification was made to alleviate problems that sound like your car's. My C5 was not showing signs of leaking BTW - this was done as a preventative.
    Aug 2005
    323
    Thanks Craig.
    I will get one of those caps.
    I don't think it will solve my problem though, but it may help in the future.
    I might need to remove the reservoir for a closer inspection.
    It might just be a leaky O-ring.
    Leon
    Aug 2005
    323
    Source of leak found to be a small crack in the reservoir.
    Leon
