Pinking in DS23: can it cause damage
Results 1 to 25 of 28
Like Tree14Likes
Thread: Pinking in DS23: can it cause damage
    Feb 2002
    Coolum Beach
    2,050
    Default Pinking in DS23: can it cause damage
    well I went for a longer drive today, something the car hadn't seen since 2006. And I'm sure she was just as glad as me.
    On the way back uphill I got a lot of pinking, most likely due to my using standard unleaded. I know next time it will need to be 98, but can I run out this full tank I've got or should I add an additive in the meantime?
    And would I create a problem with continuous pinking?
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Peugeot Boxer Van hired from T.....y, that was manual!
    and bloody good too!
    San Diego, California, USA
    3,543
    Are you running the stock ignition? You might need to set the static timing.
    11,294
    I'd retard the ignition a wee bit until the noise goes away, and start adding 98 octane fuel once it is 3/4 full. Also avoid heavy acceleration - feathertouch driving...
    I've read horror stories of piston damage but honestly have no real experience of it.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Apr 2013
    Essendon
    701
    Quote Originally Posted by harrisson_citroen View Post
    Harrisson,
    I've had occassions of unintentioally (or having no choice) of filling up with low octane fuel and without altering the timing it is unwise to continue pushing your engine to the extent of pinging due to low octane fuel.
    Pinging will damage the engine in due course. Not advisable to allow it to continue the pinging.
    Take it easy , change down/ease off on the pedal the moment you hear/feel it pinging untill ready for the next fill.
    John
    Feb 2002
    Coolum Beach
    2,050
    allrighty then, will start refilling slowly with 98 and take it easy in the meantime.
    Los Angeles, CA USA
    1,955
    Yes. It will gall the pistons and cylinder head.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Quote Originally Posted by JAJEA View Post
    Harrisson,
    John
    Not only pistons, but rods and bearings suffer too!
    Cheers Gerry
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    I believe that octane in the fuel can dissipate over time, so fresh fuel and a well sealed tank can assist with maximum octane levels.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Don't remind me!
    16,609
    The only place for aged fuel is either as a fire-starter or well-diluted in the tank of a non-fussy motor. A stabiliser is good practice; these reduce corrosion of a tank.
    8,481
    Pro-Strength Octane Booster- Nulon Australia
    WHy would you drive a car that you know is going to ping????
    Jo
    CitroŽn Tragic UFO's Avatar
    9,807
    Thankyou Harrison for calling it what it is. Pinking - meaning an incomplete ignition of the fuel load.
    Go straight to 98 as soon as you can.
    Jan 2011
    749
    Jo
    Does, this stuff really work, or is it a con?
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    8,481
    I dont know?
    Never needed it.
    Jo
    Don't remind me!
    16,609
    It does make a modest improvement to ability of the fuel to resist detonation.
    From memory, Nulon's Injector Cleaner has some additives that help, as well. But the first step is to stop being tight and get the fuel out of there.
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    Not incomplete ignition at all.
    Pinging/pinking is a symptom caused by an early or uncontrolled propagation of the flame front in the combustion chamber.
    When an engine is operating correctly, the flame front will propagate from the spark at the spark plug, and progressively burn outwards until all fuel/air mix has combusted. This gives a nice predictable and even increase in combustion chamber pressure which provides optimum power as the piston is pushed down evenly and smoothly (and the timing of peak pressure to coincide with the correct position of the piston in the downwards stroke is adjusted by precise timing of the spark).
    The pinking/pinging sound is caused when the peak pressure inside the combustion chamber occurs too early in the cycle (i.e. the piston is still heading upwards and compressing the burning fuel/air mix, which is trying to expand).
    "Detonation" is generally caused when there is an ignition source other than the spark from the spark plug - e.g. hot carbon deposits or overheated glowing spark plug tips.
    Alternatively, the heat of compression may cause early ignition (where a very high compression engine is run on fuel of too low an octane) - this is how diesel engines achieve ignition ("compression ignition").
    In this case, the problem is ignition timing. Different octane fuels burn at different speeds - lower octane fuels burn more quickly. So if an engine's ignition timing is set for 98 octane fuel, and 91 octane is then used, the result will be that the flame front will propagate too quickly and maximum combustion chamber pressure will occur too early - the result may be heard as a "pinging" sound.
    This can be addressed by retarding the timing slightly (although the ignition advance curve in the distributor will likely not be correct either, meaning a further loss of efficiency).
    The damage that can result from this problem have been described above - all caused by the piston trying to compress a burning gas. You would have to be very unsympathetic to your engine to do serious damage on only one tankful of low octane fuel.
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    Dear moderators
    can we start a new sticky on pinking, pinging, pre post detonation, farting, spewing and spitting please. Every time someone asks a question about it, someone writes an essay on the correct term(s) and meaning. No disrespect to contributors but I grow weary...
    Matthew
    Albury
    154
    Quote Originally Posted by mnm View Post
    Dear moderators
    Matthew
    Then just skip over it.
    No one forced you to open this thread, or read its contents. Skip over it.
    Saying "no disrespect" when you are being rude is just hypocrisy.
    The fact that admin types have thoughtlessly "liked" your post shows how much this site has slipped in the last few years.
    8,257
    Icon3
    Aww c'mon Trevor,
    Matthew's post was very obviously tongue in cheek and full of light hearted humour, it does follow a spate of definitions on the subject of pinking/pinging/pre-detonation or whatever you like to call it in several threads recently - a sticky on the cause(s) and effects is not a bad suggestion.
    For your information I give a lot of thought to any post I 'like'
    Quote Originally Posted by Trevor G View Post
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    16,744
    Your wasting your time putting 98 in limited use cars. The chemicals that raise the octane level apparently boil off within a couple of weeks. ............ Hey look at that, a 5second google search. Bugger me it's "goes off" in about 3weeks
    http://www.bp.com/retail/liveassets/...le_tanksv4.pdf
    NZ
    335
    Also, there is no need for 98 octane in an engine running a compression ratio as low as a DS.
    16,744
    Quote Originally Posted by Mungous View Post
    Later DS's and carby CX's need the high octane brew. They run on and ping on the slop they sell as 91. The early long stroke are fine on anything that'll burn ( what 7:1 compression ?? ).
    NZ
    335
    You don't get 95 in Oz? 98 is comparatively rare here in NZ, and a fair bit more expensive than 95. 91 is only fit for Hillman Hunters. :
    16,744
    It's around, a lot of places have phased it out .... They make more money forcing anyone that wants higher octane to buy 98
    Don't remind me!
    16,609
    Hi Matthew,
    I took the plunge and started a thread with the excellent commentary of Roger from Castlemaine (LHS2.1) As I'm on Trevor's ignore list, I felt "safe" to post this comment here.
    1,475
    That might explain why a GS feels like it's got 100HP under the bonnet once you've filled her up and driven out of the servo driveway.
    1972 SM
    1989 BX 16 Valve
