Xantia Manual Gear Change
Results 1 to 8 of 8
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    386
    Default Xantia Manual Gear Change
    Noticed the gears in the 5 speed Xantia are getting a bit tight, notchy and occasionally hard to change (sounds like a relationship).
    Is there anything I need to consider before I become surprised?
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    Don't remind me!
    16,609
    "Xantia Clutch Replacement" might be an alternative thread title...
    monbulk
    657
    I had a 406 V6 manual with 200K kms that developed similar symptoms.
    2nd gear was especially notchy.
    When I took the car to a different service centre they replaced the gearbox oil. It was disgusting because my previous mechanic had regarded it as sealed for life.
    Within hours the functionality of 2nd gear and the whole box was vastly improved.
    Potentially a cheap fix. Try an oil change first is my suggestion.
    David
    tweed heads
    1,544
    Iv found that castrol multitrax and some nulon additive [comes in a tube like toothpast ,works wonders .pugs
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    Try lubricating your linkages. My old 206cc was getting really hard to change at 3 years old - just out of warranty. Trivetts wanted to rebuild the gearbox. AP Automotive lubricated the linkages and I never looked back!
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    Don't remind me!
    16,609
    G70 is a possible additive, if the difficulties began with selecting reverse it's still likely to be clutch wear.
    Sep 2011
    eganstown
    94
    Quote Originally Posted by sparkey View Post
    Some manual Xantias have standard type master/slave cilinder setups like my 97 CT. When I purchased mine a couple of years back the clutch would not work, eventually found the reservoir tucked in the fire wall out of sight. There was no brake fluid in system so I filled it and pumped the clutch for a few days and now its as good as new.
    John
    16,749
    Quote Originally Posted by citmad View Post
    John
    I'm pretty sure only CT turbos have hydraulic clutches, the rest have a cable with the dreaded plastic clip
