Gris Rose
Results 1 to 10 of 10
Like Tree6Likes
Thread: Gris Rose
    Mar 2011
    Broom
    819
    Default Gris Rose
    Believe it or not I found an almost perfect match for Gris Rose at Bunnings Port Melbourne today for $2.50 a can. My lucky day! Simple pleasure. And a very spiffing new wheel for the 69.
    Attached Thumbnails Attached Thumbnails Gris Rose-img_2928.jpg   Gris Rose-img_2932.jpg   Gris Rose-img_2933.jpg
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Michael, This will go ride over some peoples heads. For the uninitiated maybe you can elaborate what Gris Rose is and explain to people where it should be seen.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Sep 2013
    Elphinstone Victoria
    537
    I'll be in there tomorrow. Woohoo! Gris Rose here I come.
    SF
    16,743
    Now to try and refit that without scratching it up ... I tried wrapping one in gladwrap to refit...... Still scratched it though
    San Diego, California, USA
    3,543
    Quote Originally Posted by IE23 View Post
    Hey, take it easy. You're going to start a stampede of wagon owners!
    Auckland, NZ
    69
    Can I ask what the colour is called on the can? I'll see if its stocked here in NZ, too.
    Mar 2011
    Broom
    819
    I can double check this evening when I get home. I think it was "Bushland" which is a match to a Colorbond colour. I'm very happy with it as a match, having double checked it this morning now it has dried.
    Gris Rose, on DS saloon.
    Air cleaner
    Wheel rims
    Steering column
    Turning headlight cross member
    On the Safari, you could do plenty more.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,410
    Hmmm, maybe I could re-do mine in Colorbond.
    Roger
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    It is cheap! I wonder that thing is as good as POR thing.
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    Ici.
    2,666
    POR is great stuff except it sticks like *^%# and is a B8tch to get off, I had some put on the luggage compartment and it has corroded underneath, so it has to come off, fear is what's going to be left once I grind, sand it away... The boot is (as a given) trap for moisture in the lid sponge/lip of boot and then causes corrosion south of it. I won't use POR there when I repair it as it failed and is harder to repair as a result, I guess if the area isn't completely sealed or prepped correctly in the first place you are up for more trouble. Putting on a steering wheel is overkill as it isn't exposed to moisture, you would hope!
    When i repaint the engine bay I am going to use zinc primer and satin black cans, maybe some clear coat over the top. POR is too extreme I think, POR better suited to heavy duty industrial gear. My steering wheel on a 74 DSpecial is black too so somewhere they just painted it with whatever was around I guess, the sleeve is gris rose however. Might go looking for that colour up here, cheers
    Steven
