DS oil in spark plug tube
Results 1 to 8 of 8
Thread: DS oil in spark plug tube
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    633
    Default DS oil in spark plug tube
    Got a fair wack of oil in number 4 plug hole, could there be a hair line crack in the metal tubes, as i cant see how oil can get in there as the tube protrudes above the rocker cover, anyone had any experience with this issue?
    Via the aussiefrogs App
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Default Tappet Cover Seal
    Quote Originally Posted by Balki View Post
    The tappet cover seal plug is likely leaking.
    Ever removed a tappet cover? Reckon you will now.
    There is a round seal for each plug hole, the tappet cover gasket is probably as hard as a goats forehead, worth changing it too.
    Hope this helps.
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    I just replaced all 4 seals on my car. One of them was cracked and there was oil in the tube. When I replaced the tappett cover and screwed it down two of the news seals split! When the engine was running, with the spark plug cover removed you could see oil spitting up the tube. I didn't do it up that tightly but be careful.
    Matthew
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Some times the metal tube is not an oil tight fit in the cast aluminium of the head. IT CAN LEAK AT THIS POINT. If the seals on the rocker cover are leaking it is more likely that the oil will be seen on the rocker cover rather than fill up the sparking plug tube. If the tube is loose it is an easy job to remove it, clean the head where it sits and reinsert it with some silicone sealant or Loctite!
    Cheers Gerry
    Sep 2013
    Elphinstone Victoria
    537
    Quote Originally Posted by mnm View Post
    Matthew
    Is it possible to source just these seals as opposed to a complete top end gasket set?
    SF
    Sheffield/Tasmania
    633
    Thanks for that, it is completely dry around the top so will check if i can get the tube out, i have cover of already
    2016 Cactus
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    1000+ Posts Goddess fan's Avatar
    Oct 2013
    Tasmania
    1,452
    Yes, Roger Parker supplied me with the 4 round seals, and a rocker cover gasket. Four new, and not oil soaked, tubes too. Cheers.
    mnm
    mnm is offline
    Dec 2010
    3,236
    Quote Originally Posted by ScotFrog View Post
    SF
    Yes, they are readily available from most suppliers.
    Matthew
