help !crunchy berlingo clutch pedal
Results 1 to 3 of 3
    Oct 2003
    canberra
    871
    Default help !crunchy berlingo clutch pedal
    Clutch pedal sometimes makes a crunchy noise when depressed ,
    now often refusing to return to height .
    have lubricated joints, not helped,
    is this to with the cable or the pedal?
    curiously if slight depression kept on the pedal neither seems to occur
    10,192
    Change the cable, which is inexpensive. They commonly bind internally and lubrication doesn't solve the problem. You will be amazed at the improvement, assuming the release bearing is not about to let go.
    Oct 2003
    canberra
    871
    Thanks David will change cable
