AL4 filler plug tool size
Results 1 to 15 of 15
Thread: AL4 filler plug tool size
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,250
    Default AL4 filler plug tool size
    Anyone know what is the size of the square tool needed to remove the filler plug on my Xantia's AL4 box, or where I should attempt to procure one?
    Via the aussiefrogs App
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    I did our Xantia the weekend before last and the socket is still on the long extension. It is an 8mm square plug. I bought it from the local Pep's spares as part of a set. It is made by Kingchrome
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Apr 2001
    1,250
    Thanks Greg
    I'll start hunting for one.
    Bruce
    Bruce H
    Apr 2013
    Essendon
    701
    Quote Originally Posted by Bruce H View Post
    No idea. But for what's it worth, I was tossed by a similar dilema some time ago with the sump plug of a small engine when I tried the standard 1/2" (or was it the 3/8") square drive tool set. It was a perfect fit.
    [If it's a 13 or 10mm plug, they'll fit even though a little bit undersize.]
    John
    Apr 2013
    Essendon
    701
    Thanks Greg
    Bruce
    Try hunting in your tool box for an old 3/8" square drive - would not take long to grind 1mm off each side.
    John
    (PS: Unless you need a new Kingchrome set of tools - I like Kingchrome by the way)
    Don't remind me!
    16,609
    Don't you love autocorrect - it's actually Kinchrome.
    Draper 38324, arrive within ten days, $12 or less.
    Fellow Frogger! Clogzz's Avatar
    Mar 2005
    Sydney 2087
    189
    8 mm square, like a door lock shaft.
    Bunnings sells them separately for about $2.
    2003 C5 2.0i AL4 205,000 km 76372389
    May 2012
    393
    Quote Originally Posted by Clogzz View Post
    The filler plug on our GS C-Matic (convertisseur box) is also 8mm, I bought the kingchrome set with one in it BUT it is too short because the wider round section for a socket fouls on another fitting above where the plug is. So, an extended bar like this one is what we need, i believe the axle on domestic doors is 8mm square as clogzz rightly says so we too will be looking for something more like this than a short 8mm square drive but short socket accessory.
    Regards, leconte
    1962 Heidelberg ID19 "Axel"
    1965 Heidelberg ID19
    half owner 1974 GS 1220 Convertisseur Break
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,412
    It's actually Kincrome.
    Cleverly named, I suggest. In my (biased, snobbish) opinion it is neither king nor chrome but implies it is both.
    I'm not sure that would be hard enough.
    Roger
    Mar 2005
    Sydney 2087
    189
    Same on the C5, the gear selector shaft is very close to the filler plug.
    The door lock shaft looks like proper steel and has been good and strong.
    The plug was a bit firm at the first opening but I never tightened it too much since.
    The welding teacher at the part-time welding school next to my old scrap of work in Queensland welded a nut onto it at taxpayers’ expense.
    Attached Thumbnails Attached Thumbnails AL4 filler plug tool size-al4_filler_plug_tool.jpg
    9,292
    Eons ago I had a vehicle that used square drain keys. I looked through my old tools for a square file (they are gently tapered, and are hardened), and cut it off at the right spot to make a piece about 50mm long. The rest is still a file. With a large shifter for leverage this did the job for 25 years. It's still weighing down my toolbox, but too potentially useful to chuck out.
    Fellow Frogger! FedGrapes's Avatar
    Aug 2011
    Perth, WA
    839
    I found an 8mm square socket in the Snap On truck that drives around Perth. I've seen them once or twice since then, but they aren't common.
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,350
    Just get a Renault sump plug tool. There 8mm square drive and we (French connection) sell them for about 10 bucks.
    2017 Renault Koleos auto
    Oct 2013
    Epping
    108
    Grind a bolt down square on a bench grinder
    Apr 2001
    1,250
    Part ordered from French Connection, thanks all.
    Bruce H
