Well I never...
Results 1 to 22 of 22
Like Tree8Likes
  • 1 Post By addo
  • 5 Post By badabec
  • 1 Post By IE23
  • 1 Post By Peter O
Thread: Well I never...
    Don't remind me!
    16,609
    Icon7 Well I never...
    Working for a fellow with a 2CV in his shed, he told me the choke knob lights up, rather than a dash light.
    Skeptical, I looked at it and went "nah, impossible. There's only one wire going in. It must light a globe on the dash." He demonstrated it, and I am convinced. Damn clever!
    Mort Subite likes this.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,066
    Damn Electrickery!
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,240
    It does on one of mine (which is original), but not on Daffy Duck. I replaced it with a standard choke cable on Raid 2008 as the original had seized up. My only problem is when I am feeling under the steering wheel to push the choke in, I sometimes hit the ignition on/off switch and cut the motor. I quickly realise my mistake and pull the ignition back on, usually to be rewarded with a backfire. Daffy Duck doesn't have a key start nor a steering lock. The last thing you want to find out in the bush is that you have lost your keys or the steering lock actuates inadvertently. Much easier to have a push/pull ignition switch and a starter button. No one is ever going to steal a bright yellow 2CV.
    John
    Banned
    sydney, australia
    11,301
    is that because of the colour, or something more fundamental?
    Feb 2012
    Ongar / England
    832
    Because the choke knob doesn't light up
    San Diego, California, USA
    3,534
    Yah, I could explain that, but damn, I have to keep some sekrits.
    Don't remind me!
    16,609
    I worked that one out because he showed me one taken off the car; globe replacement is very sneaky too.
    Told him to hit Steve (citroenfan) with his carb questions - I haven't looked up the skirt of a carby for fifteen years.
    JBN
    JBN is offline
    8,240
    What are his 2CV carby problems? I've had most of them and ended up solving my nightmare by buying a new double throat carby. They are manufacturing the late model carbys (602cc disc brake models) in India. The quality control is a bit iffy, but if you score a chief rather than an indian, its all good. I was lucky and scored a chief.
    John
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,070
    My CX does that. He has probably installed a cable from a CX. There is a wire that clips to a contact built into the choke cable fixing behind the panel. When the choke knob is pulled out the contacts earth on the choke cable slide, down the cable wire, to the engine! Brilliantly simple!
    Cheers Gerry
    3,534
    Yah, pretty easy. The bulb doesn't care where it gets ground, just so long as there is a return path to battery.
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    picture helps tell the story
    addo likes this.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    lost
    11,055
    Icon6
    It does on one of mine (which is original), but not on Daffy Duck. I replaced it with a standard choke cable on Raid 2008 as the original had seized up. My only problem is when I am feeling under the steering wheel to push the choke in, I sometimes hit the ignition on/off switch and cut the motor. I quickly realise my mistake and pull the ignition back on, usually to be rewarded with a backfire. Daffy Duck doesn't have a key start nor a steering lock. The last thing you want to find out in the bush is that you have lost your keys or the steering lock actuates inadvertently. Much easier to have a push/pull ignition switch and a starter button. No one is ever going to steal a bright yellow 2CV.John
    G'day,
    why not? They stole a mango...
    Bowen's Big Mango attraction goes missing in north Queensland - ABC News (Australian Broadcasting Corporation)
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    May 2013
    171
    On the 425 6volt ex La Poste AZUA we hace, the choke cable knob lights up, well it does when the cable is not broken anyway. Have been told that a possible replacement is from a Fiat 500 of the era. However while they may be freely available in Europe, they are somewhat scarce on the ground in Oz. Cable is quite a bit longer than for the later 425 and 602 cc engines and follows a somewhat circuitous route in engine bay.
    Seems this also helped to function as a cabin light, as the 6volt interior light is somewhat lacking in illumination. The choke cable light is considerabley brighter, and being red does not affect night vision!
    Well that is my story and I am sticking to it
    Oh re the Fiat comment, cable broke in Cherbourg on way back to ship van to Aus from Southhampton. Did not have time to get a replacement cable then, but was given helpful advice re Fiat 500 cable. As emergency used spouse to stand in rain head under hood to hold choke while i started car. Let her in once running and as this worked have yet to getcable fixed. Must do so one day :-)
    Peter
    1950 11BL
    1970 AZUA "La Poste" van
    1986 2CV Dolly (red and white)
    2004 C5 HDi silver 2.0L
    JBN
    JBN is offline
    8,240
    Yes, before the wife dissolves.
    John
    Sep 2013
    Elphinstone Victoria
    535
    In tears
    John
    in tears!
    May 2013
    171
    She is tough, from Brittany, so drizzle and rain is natural for her!
    Yikes, she is reading over my shoulder - please put that down ....AARGH
    Whimper :-((
    ScotFrog likes this.
    Peter
    1950 11BL
    lost
    11,055
    Icon6
    Quote Originally Posted by Peter O View Post
    G'day,
    if it is just the knob you are after, the hazard switch on some VW kombis and Golfs, and others I suspect, has a light inside. It is a pull on knob affair.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Sep 2013
    535
    Quote Originally Posted by pug206gti View Post
    G'day,
    Pull on knob affairs are often quite popular.
    May 2013
    171
    No the cable is snapped somewhere in the middle. Think I should be able to get it fixed, just a matter of getting a "round tuit" to fix!
    Peter
    1950 11BL
    1000+ Posts dino's Avatar
    Nov 2002
    4,591
    Quote Originally Posted by badabec View Post
    love, love, love it... as sharp as lemon juice on a razor blade...
    lost
    11,055
    Icon6
    G'day,
    I had one of them once, but I think I lent it to someone.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    3,534
    G'day,
    No more excuses. Get with it.
    Attached Thumbnails Attached Thumbnails Well I never...-round_tuit_225quot_button.jpg
