Early DS/ID part
  • 1 Post By Hotrodelectric
Thread: Early DS/ID part
    castlemaine
    503
    Default Early DS/ID part
    I've been messing with early D's for many years, but I was recently given a part which I had not seen before. Unfortunately, it wont photograph well so I'll have to describe. It's a plastic disc (probably nylon) 115mm dia, about 2mm thick, with a central hole 20mm dia. Probably natural nylon colour originally but has aged to yellow.
    It is plain on the front, and on the rear it has raised lettering which can be read from the front.
    It fits on the securing pin of the DS/ID jacking arrangement.
    The instructions are thus:
    NE PAS PEINDRE LA PARTIE CACHEE
    PAR CET ECRAN
    MAINTENIR
    LES MOYEUX ET LE VIS
    PROPRES ET GRAISSES
    Anyone seen this before, and can we have a translation?
    roger
    Don't remind me!
    16,609
    Icon7
    Don't paint the bit underneath
    Then - at a slight guess...
    Maintain the hubs and screws (wheel bolts) with the correct greases.
    San Diego, California, USA
    3,534
    Quote Originally Posted by lhs2.1 View Post
    PAR CET ECRAN
    MAINTENIR
    PROPRES ET GRAISSES
    roger
    Yah, I have seen them. It goes on the jack pin/hubcap tool. Spare wheel-jack stand-jack pin-plastic thingamabob-tire strap. I'm not sure of the translation. I **think** from MAINTENIR it's advising to keep the center wheel stud and mount flange properly lubricated. Harrison Citroen will have a better idea. If he doesn't respond here, I'm sure a PM will do.
    addo likes this.
    Jul 2003
    317
    Google translate!
    DO NOT PAINT PARTY HIDDEN BY THIS SCREEN AND RETAIN HUBS VIS EQUITY AND FATS...
    Sent via the future...
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,070
    Yes I have seen this before. It merely keeps dust and grit off the inside of the hexagon on the spare wheel when it is not fitted to the hub. It should be kept lightly greased ready for use. The warning is against applying paint to the inside of the hexagon. Makes sense if you want good metal to metal contact on the hub.
    Cheers Gerry
