D Special headlight assembly
Page 1 of 3 123 Last
Results 1 to 25 of 65
Like Tree13Likes
Thread: D Special headlight assembly
    Aug 2011
    407
    Default D Special headlight assembly
    I have been adjusting the headlight set up on the D Special (and yes, have consulted the 814 manual op 540 pp393-400).
    So far so good. All appears to be in place, with one exception. I can't figure out how the small rod (that connects the cross section bar/lever to the main headlight) attaches to the headlight housing. The end of the rod is like a rivet, and is not threaded. I had figured that it was a simple "pop on/press in" mechanism, but it keeps coming loose. As a result the headlight assembly swings up and down, against the movement of the car...
    There doesn't appear to be any diagram or cross section which explains it. I am sure it is very straightforward (which makes it all the more frustrating), but I can't for the life. Maybe a plastic clip has worn or perished (or gone missing)?? Can anyone advise....?
    AM
    Fellow Frogger! Mort Subite's Avatar
    620
    If I understand correctly, the adjusting rod that is threaded screws through the rubber sleeve on the ends of the 'balance bar headlight to headlight. The rod has a nipple end that presses into a smaller rubber 'cup' that is on the outer edge of the headlight. Assuming you have the Amplilux headlights and not changed for after market units without the adjusting 'cups'. if the rubber cups on the headlight have failed (quite likely after 40years) you may have to fabricate replacements or find headlights with usable rubber cups.
    UFO likes this.
    CITROEN CAR CLUB of NSW - MEMBER. www.citroencarclub.org.au. . .www.facebook.com/CCCNSW
    08FD DSPECIAL "Dear Prudence wont you come out to play?"
    00FF7512 DS23SAFARI "Pull up to my bumper Baby, in your long black limousine."
    C2MY06 C2VTR "Go speed racer, Go"
    YDO005 MORRIS MINI DELUXE "The Mini Deluxe floats on fluid too"
    Aug 2011
    407
    Ok. Yes you do understand correctly. The rod does have a nipple end. The car is very original so I assume it is the ampilux headlights. And the rubber cup seems to be missing. Hmmm. Many thanks, i will rack my brains for a bit...
    8,184
    Quote Originally Posted by ajaxvte View Post
    The clip at the headlight is nylon not rubber. The clip fit is quite tight, are you sure the adjuster is actually clicking home?
    If the nylon is missing or badly worn, I may have a few I can mail to you.
    Mort Subite likes this.
    08 C5 X7 HDi very Noir
    Citroën Tragic UFO's Avatar
    9,721
    Nothing worse than when your nipples won't click into their clips and you end up with your headlights pointing up and/or down when you least expect them to.
    ScotFrog and Lasya like this.
    9,774
    Is it worse in winter UFO?
    Yes, should snap in with a firm push. It operates like a ball joint as the crossbar moves it fore and aft. Does the long cable from the rear axle still move when the rear suspension is moved? If the damping device is untouched original, it may need repair, which involves cleaning and replacing two rubber diaphragms, same as used in a height corrector.
    San Diego, California, USA
    3,534
    That sounds more like a quandary for Dr. Ruth than for this board, Craig. I personally know nothing of clicking nipples.
    Sep 2013
    Elphinstone Victoria
    535
    I have it on good authority that 'cracked' nipples getting caught in clips is agony. Best proceed carefully.
    3,534
    Quote Originally Posted by ScotFrog View Post
    Hey now. Don't be judgmental. Some pay extra for that.
    Oh, errrr, ummmmm, that wasn't what you meant? Awwww jeeze, ok. Move along you lot. Nothing to see here.
    Jun 2002
    68
    Had the same problem with my D lights recently. The nylon cups are available from roger parker at oleopneumatics
    Via the aussiefrogs App
    Aug 2011
    407
    Thanks Greenblood. Will PM you.
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    435
    Ok, would anyone know where to get those nylon thingies in, say, Europe?
    If it's these, Franzosen et al want €10 a pop for them.
    Which is obviously not acceptable.
    Thinking I might need 6 or 8...
    https://www.franzose.de/en/Citroen-D...ngen/ANR35469/
    8,184
    Quote Originally Posted by Don B. Cilly View Post
    That looks like the nylon bearing for the headlight tilt, if so, you would only need 2 one each left and right for the light bar where it fits through the guard. Part#15 in the illustration
    Do you mean the small nylon clips that fit on the headlight for fixing and adjustment screws?
    Dec 2014
    Mallorca, Spain
    435
    Yes! Where are they? To buy I mean.
    Those threaded rods have a nipple thing on the end.
    Supposed to go into something.
    They go into an assortment of duct tape, rubber tape, silicone, foam and glue stuffed into the fittings on the headlight frames - none of which work too well at all.
    I wouldn't mind getting some proper fittings.
    Dec 2014
    Mallorca, Spain
    435
    This is a piece I recovered.
    It seems to click onto the nipple, but must be missing a bit on the other side as it does not click onto the frame.
    3,534
    Try here, Marco. Sylvain's prices aren't stupid expensive and he's pretty quick about shipping.
    Dec 2014
    Mallorca, Spain
    435
    He really doesn't seem to have any of those.
    Which is interesting, because neither do Citrotech, Citroworld, Citroservices, Franzose, Beeblebrox Spares or Hollywood Props.
    Which is even more interesting, because if you 3-D scanned one of those, you could 3-D print them out at 10 per second, at 10 cents a pop.
    Which is even more and more interesting, because, judging from the state in which I found all of those that were on Sophie, one starts to think that there may not be a single one in the galactic sector in good enough shape to be 3-D scanned.
    Which is puzzling, because if there aren't any left in ZZ9-Plural-Z-Alpha, how do people in this sector keep their D headlights pointing at the road?
    Can you guess how long it takes to ship from Betelgeuse?
    3,534
    I think those pieces are nylon. So far I haven't found anyone that can do nylon in 3D- yet.
    One other place that I just thought of would be Citroen Classics in England (Darren Brownhill). You'll need to enquire 'cause he doesn't put up any more than a representative sample of wares on his site. He's pretty fast on response.
    Betelgeuse is probably fairly quick with shipping if only you will invoke his name 3 times in succession. Bet that the charges aren't just outrageous, they're a nightmare.
    Dec 2014
    Mallorca, Spain
    435
    Actually nylon is one of the most commonly used 3D-printing materials.
    Cheap too.
    https://www.3dhubs.com/san-diego ;·)
    If you click Nylon under "Which material should I use?" you should find quite a few.
    I can also find a lot of 3D scanning services there.
    Have you got one to scan?
    That Citroen Classics site looks good. Again those bits don't seem to be in the catalog, but I'll ask. Thanks.
    Pity about the eur-gbp exchange rate at the moment...
    Dec 2014
    Mallorca, Spain
    435
    I guess I'm only joking up to a point.
    Because... I haven't got one of those in decent condition, but if anyone got around to actually having one scanned, and uploaded the .stl file, we could all have them printed cheap.
    I mean, well, they do seem to fail a lot, and you can't friqqin' find them...
    8,184
    Icon12
    I'm sure they are available, but like you I haven't been able to find them
    I've got a few stashed somewhere, and we have our resident 3D Printerman Scotfrog so I'll make contact and see what can be done.
    Dee Plastic Bits
    Othello in Switzerland is right into reproducing plastic parts for the D but doesn't appear to have these as yet
    FABRICATION DE PETITES PIECES PLASTIQUES EN 3D. | Citrothello
    Dec 2014
    Mallorca, Spain
    435
    Yes, well, is just how I feel too.
    Have one scanned!
    Keep in mind that nylon filament is as cheap as any, but it needs a slightly "hotter" printer than most...
    But really, if we could have a .stl file for it... I can find nylon printing services in the area, so I guess everybody can too.
    8,184
    Icon3
    Have one scanned!
    Nothing is as simple as it first appears, there are two parts. . .
    The part you seek is fitted to the bracket on the light rim and held in place by the second part.
    That second part could be substituted with a squirt of silicone. . .
    I'll get in touch with Scotfrog who may be willing to scan the part you need and send you an .stl.
    Attached Thumbnails Attached Thumbnails D Special headlight assembly-d-light-clip3.jpg   D Special headlight assembly-d-light-clip2.jpg   D Special headlight assembly-d-light-clip.jpg
    Sep 2013
    535
    Cheap too.
    Printerman here.
    I'll undertake to model these parts. I won't be able to start till early next week and hopefully the ones in my DS are good enough to throw a ruler over. (Better than 3D scanning since I can correct my data to take account of any irregularities caused by wear). I'll post a link to the STL file once I've finished. Just download and take to your printer bureau. If someone has a new unadulterated part which they can loan me then the result will be better.
    And yes, nylon is becoming more generally available.
    SF.
    GreenBlood likes this.
    Sep 2013
    535
    We must have crossed in the mail.
    Actually looking at the photos you posted Chris this part could be easily reproduced on a lathe. When I model it I'll also convert to a dimensioned drawing for those who want to go down that path. Thinking further it might be worth while approaching a shop with a repetition lathe and getting a bulk price.
    SF
