'70 DS Radiator questions
Results 1 to 10 of 10
    Nov 2013
    Wellington, NZ
    13
    Default '70 DS Radiator questions
    Hello!
    I have just removed and replaced the radiator on my DS as it required some leaks to be fixed. I'm wondering if anyone can help with the following -
    - Should the filler neck have an extra seal at the bottom (over and above the seals built into the cap)? I filled the coolant up but when the pressure builds there is a constant flow out of the overflow pipe half way up the filler neck.
    - I'm filling the coolant to the top. Would the above symptoms mean I'm putting in too much? Where should the 'cool' level sit?
    - Would anyone recommend fitting an additional cooling fan? Our temperatures are not quite as balmy here in NZ as they are in Australia, so maybe this is not really necessary?
    Many thanks!!
    Dean
    16,423
    Is it a crossflow radiator ?
    Los Angeles, CA USA
    1,955
    No extra seal on the neck. Only on the cap.
    Cap should be 4 pounds. 7 pounds in a pinch.
    You likely need a new cap.
    Coolant should stay full at the bottom of the neck.
    Install an overflow container on the bottom outlet of the petcock.
    Secondary fans are fine. A healthy car without aircon should have no need for one.
    Nov 2013
    Wellington, NZ
    13
    Thanks for your reply. The cap is new, so I will take your advice and install an overflow container and go from there. Many thanks.
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    Quote Originally Posted by daffyduck View Post
    Yeah mines the same! I always fill it up full all the way to the top like modern car and every time I check it water is gone! SO I guess that is normal. I also should put reservoir tank. But I can only put in between radiator and spare wheel. And it will block airflow to radiator slightly. Will that cause problems?
    Where would you put?
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,228
    Hello
    I've just replaced the coolant in my D Special, the owner's manual says to fill it to 2-3cm below the bottom of the filler neck. It is not the crossflow set up.
    Matthew
    16,423
    Quote Originally Posted by caparobertsan View Post
    Everything expands when hot, so it'll push the coolant out. It'll prbably drop down a couple of centimeters and settle at that level. Later cars with a crossflow radiator and header tank, will just have a higher level of coolant in the header tank when hot.
    Los Angeles, CA USA
    1,955
    Probably on the passenger side. I usually use one of the radiator shroud bolts to attach a bracket.
    With a longer hose, you could use just about any bottle that will fit anywhere until you can find something less bodgy.
    Via the aussiefrogs App
    1000+ Posts michaelr's Avatar
    1,393
    Quote Originally Posted by Deano View Post
    Hi Deano. The mysteries of older cars eh?
    The original radiator is designed to have an air space above the fluid. If you fill it to the top it will simply be ejected every time as the coolant expands. You have already found the correct level to fill to... just don't top it up any higher than it is now and you will be fine. There is no need to change anything, just check occasionally.
    Later radiators are designed to be 100% full and have a hose leading to a header tank, which has the pressure cap fitted, and fills and empties according to coolant temperature, but again this "expansion tank" is never 100% full so as to allow some air space for expansion ... air will compress, fluid will not!
    There is an "in- between" system popular in the '70s which converted a radiator like yours to a "no loss" system. In that case the small overflow hose from the top of your radiator can be fed into a non pressurised container with the intention that as the radiator cools it will suck the fluid back into system. For this to happen you will need a radiator cap which has not only the pressure regulating spring loaded valve but also a top seal under the top part of the rad. cap., otherwise it will suck air, not fluid from the overflow container.
    Michael
    Member, Citroen Car Club NSW
    Symar/ca/usa
    607
    Deano,
    Regarding caps - you can quite safely use an 0.5 atm cap (7psi) on a D. The only caveat is that the supply and return hoses be in decent shape. The up side is that the higher pressure cap also raises the boiling point of the coolant significantly - about +16F over a 4psi cap. The other thing to check is the thermostat. Make sure it is opening fully and at its rated temperature. Easy to do with a candy thermometer and a pan of water.
    Steve
