How to mount an 11BL on a Rotisserie.
Results 1 to 7 of 7
  • 1 Post By JBN
Thread: How to mount an 11BL on a Rotisserie.
    Brisbane Australia
    162
    Default How to mount an 11BL on a Rotisserie.
    I am in the middle of a restoration of an 11BL and to make life a little easier I bought a Rotisserie to make work underneath the car simpler.
    Mounting the front of the car is a no brainer but mounting the back is where Iím having the problem. I donít want to damage to car or leave great tell tale holes.
    Advice, particularly in the form of pictures, would be greatly appreciated.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,234
    Don't you just remove its head, gut it and stick a big long pole up its bum?
    John
    ScotFrog likes this.
    16,423
    9,774
    I suppose the bumper mounting points could be the first thought for many cars, but on your 11BL they may have rusted out at the back and the front bumper extensions are only light gauge sheet. You may need to make up a bracket to run forward to where the rear beam bolts up at the back of the sill. If that's rusty, then you may have to think of some other way to support that corner when you repair it. If the wheelarches are OK and can support the weight, then maybe the shock absorber mountings could be useful.
    It's how I roll...Brisbane
    33,175
    There are quite a few versions on youtube that would give a few ideas how to mount your car, from personal experience, to avoid accidents, strength and rigidity is important and so if estimating the centre of gravity. If the COG is too far out you will have to wrestle with the weight of the car to rotate it, but if you get it correct it's quite easy and safe.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,254
    Mate fabricated one and had a handbrake on it. He was into Mazda's and it used a Capella rear drum, lever and factory cable (neatly coiled and restrained). "At least it keeps some of the spares in plain sight and working for an honest living."
    Brendan.
    Brisbane Australia
    162
    Thanks to those who took an interest, especially jaahn for the photos forwarded by PM. I will post photos when I do eventually mount it.
