BX misery continues
Results 1 to 10 of 10
    Jan 2006
    TRARALGON Vic
    43
    Default BX misery continues
    OK I hope someone who has done this job suggests some easier way to do it.
    Octopus stuffed so I managed to get one from Big and little Mick. So far so good, but
    the installing of the new one is a nightmare particularly the 4 and 5 mm plastic tubes that
    enter the octopus from the rear. No way can I hold them in my bruised little hand and since
    it is a push fit some force is needed. I imagine the sequence is: do the rear tubes first, then the
    suspension and height corrector, next the 4 and 5 mm tubes from across the cross member and
    finally pull the long rubber tubes to the reservoir.
    Somewhere I read that the job should take 4 or 4 hours - pure fantasy requiring a magic wand.
    Once again advice from someone who has done the job would be appreciated.
    Thank you in advance,
    rimzit
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,047
    The only way I could do it was to use some really long needle nosed pliers and not be too afraid to give the nylon lines quite a big squeeze. Even when I wet the outside of the pipe and the hole in the octo with LHM, I could not get them in that far, certainly not up to the collar that is a little way up the tube. Seems to have worked OK since them for me.
    That was a few years ago on my BX TZi. Frog has just done his BX 16 Valve in the last week so he might have some more and fresher good ideas.
    Ken W
    CitroŽn Tragic UFO's Avatar
    9,787
    Frog's thread had very good instructions
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    I always remove R/H driveshaft and rear engine mount - gives more room to grab things and push! Long needle nose pliers are brilliant for this job.
    11,220
    My sympathy. This is a job I paid to have done, perhaps ten years ago. Yes, about 4 hours labour, but he'd done a few...
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Fellow Frogger! frog's Avatar
    Feb 2006
    600
    See the last page of the thread in my signature. Looooong needle nose pliers are your friend!
    Nowra, NSW, Australia
    237
    Fortunately I had the engine out for a rebuild, so took the opportunity to do it.
    Jan 2006
    TRARALGON Vic
    43
    Thanks for all the helpful suggestions fellow enthusiasts. I'm finally at the end of the misery - did take out the driveshaft etc. the final bit was turning the steering hard to the right. That gave a bit more space to push the two nylon(?) tubes home.
    As Dr. Phil says "What were they thinking??", I refer to the crazy frogs who designed(?) this part of an otherwise elegant machine. Even though the French tart is 24 years old, it looks good and performs faultlessly apart from bleeding green blood now and again.
    Thanks once more to all.
    Rimzit.
    NZ
    335
    Good work! Not a fun job at the best of times, and worse when on the ground.
    I did the octopus on my track car a few months back, and then it almost immediately sprung a leak in the distribution hose - which runs from the front height corrector, up next to the octopus by the cambelt, and also goes from the reservoir to the FDV and under the motor to the power steering. Check the condition of the rubber t-joint at your FDV for (some) peace of mind! It is a lot easier than the octopus to replace.
    25yo rubber isn't getting any less perished I guess.
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    417
    Glad to hear your still sane
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
