Xantia V6 auto transmission removal
    Oct 2003
    Hampton Park
    523
    Default Xantia V6 auto transmission removal
    Does anyone know if the 4HP20 gearbox can be removed from beneath the car without removing the sub frame that the suspension is mounted on?
    It looks like there is not enough room as the drive shaft side will not clear the sub frame
    Haynes says it is done that way for the 4 cylinder motors but I don't know about the V6 it just doesn't appear to have the room
    Don't remind me!
    16,609
    I can't see how it would be feasible. Even the AL4 is a squeeze.
    If you unbolt the rack from the subframe, there's not too much left - pipes can be prised off with their clips attached. Putting in an ML5T?
    Oct 2003
    Hampton Park
    523
    Tempted
    I have both options available
    Dec 2002
    Menzies Creek
    2,555
    Can't say I've tried it in a Xantia, but in a 406, I wouldn't even consider trying - it takes less than an hour to remove engine and gearbox (as a unit) out from the top.
    Scotty
    Melbourne - Dandenong Ranges
    1999 Peugeot 406 Coupť - 'Chloe' - 5 speed manual
    2014 Peugeot RCZ - 'Remy'
    10,094
    I've seen it done on a V6 by a very experienced Citroen mechanic, but it is rather tight and you'll want a hoist. Given the quantity of now brittle rubber and plastic, you are probably better off carefully removing the engine and gearbox and then doing the split. Even then, expect to break half a dozen bits of plastic, especially some of the cooling system.
    Oct 2003
    Hampton Park
    523
    Thanks fellows
    I will try the engine/transmission out the top
    It will only take removing the engine mounts as everything else is done
    Thanks again
