GS Doorlock
Thread: GS Doorlock
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    374
    Default GS Doorlock
    has anyone had experience restoring GS/DS door locks and any special comments or tricks. i missed a set on eBay DE and still kicking myself.
    so going down the path of di mantling and trying to restore, like the DS the inside has pitted badly and would have to be ground back and filles or something else done.
    if anyone out in AF land has a NOS set just waiting to be bought please PM me, otherwise any advice will be appreciated.
    Attached Thumbnails Attached Thumbnails GS Doorlock-img_2060.jpg   GS Doorlock-img_2061.jpg   GS Doorlock-img_2062.jpg
    10,094
    The GS and DS handles are very similar and one can convert a GS handle to suits a DS(, which I've recently done to a couple of NOS GS handles - Sorry!) The mechanism is slightly different as I recall, but you can slide the long pin out and swap everything as needed to make a car set. There are repro handles for the DS listed by Franzose, so they may be worth looking at. Otherwise, old handles would need to be rechromed, which is likely to present some problems with die-cast metal. Also, be very careful not to overtighten the studs and nuts when refitting the handles as you will end up with a visible depression on the outside.
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    381
    Quote Originally Posted by lamoor View Post
    lamoor - had the same issue with mine. Bit of light steel wool work and extensive chrome polish by hand brought mine up reasonably.
    If you have problems with the locks themselves, that's another kettle of fish. There is a little pin that tends to break off at the end of the barrel that won't allow you to lock the car. If that is not an issue for you, I won't rabble on, but I do have a possible solution if that is the case.
    Have attached coupla snaps of final product (mine appeared a bit similar to yours before their rejuvenation)
    Attached Thumbnails Attached Thumbnails GS Doorlock-img_0088.jpg   GS Doorlock-img_0090.jpg
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    sydney-newport
    374
    Default GS Doorlock
    Quote Originally Posted by sparkey View Post
    thanks for the heads up sparkey. will try to polish if this fails then might have to go the DS door lock road. will email some EU supplier to see what the cost and of they are remanufactured with new technology or refurbished old door locks. the beat goes on !
    Member artisan's Avatar
    May 2004
    Ferny Creek Victoria
    72
    Hi Lamoor,
    If polishing doen not do the trick then it seems Daniel Engelhardt has some.
    Door handles etc. GS/A - FranzŲsische Klassiker - Onlineshop
    Cheers Andrew
