vibration C5
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By citroyiannis
Thread: vibration C5
    May 2012
    Moree NSW Australia
    53
    Icon8 vibration C5
    I drove my 2007 C5 2.0 diesel over some ruts in the road and now it has developed a vibration when I rev the motor and makes a lot of noise on the driver side up front like its rubbing or vibrating against the plastic underneath. No lights come on everything seems OK. Does have trouble with noise and power. Afraid to drive it. Mate seems to think exhaust pipe but don't think so. Engine does not seem loose. Rules out engine mounts. Idles well. I'm really cheesed of as I have spent 800 fixing the rear control arms recently. Please help me with answers. Peterbuc
    10,093
    Engine and gearbox main mounts can snap the stud and it can then 'walk'. See if the alternator pulley will still freewheel. It has a one-way clutch in the pulley and they eventually jam, which causes a lot of vibration at low rpm. You can replace just the pulley unit if you can find the part, but it's likely Citroen Australia will only sell you a complete alternator. Also check the state of the crank damper as they do eventually fall apart.
    May 2012
    Moree NSW Australia
    53
    Thankyou for your answer
    May 2013
    171
    Also check if the engine cover is loose. It can make a hellavu racket.
    Not sure if is the same as on our 2003 model, but i mean the plastic engine cover that hides everything and makes it look pretty!!!
    At some stage when the car was being "serviced" some mechanic must have just tried to pull the cover off without undoiing the fixings. Some must have broken there and then, while others were strained and broke much later. Only little bits of weak plastic material so now I have easier access with no cover in there!!! It may be that simple, hope so for your sake
    Cheers for the New Year
    Peter
    1950 11BL
    1970 AZUA "La Poste" van
    1986 2CV Dolly (red and white)
    2004 C5 HDi silver 2.0L
    10,093
    Quote Originally Posted by Peter O View Post
    Different mounting system, but a good thought. For your 2003 model, you might want to buy a set of new mounts:
    Engine Cover Clip AND Bolt SET X 4 FOR Citroen C4 C5 Xsara Xantia 2 0HDI | eBay
    May 2013
    171
    Thanks David for the link. Might have to get off the back end and do that. Had not bothered up till now as leaving it off solved the rattling, and i was reluctant to check the spare prices at the local dealership!! No excuses now, especially if the other half hearsvof this. Oh well, call it a New Year resolution.
    Now where is that drink
    Peter
    1950 11BL
    Dec 2013
    Nicosia/Cyprus
    9
    Hi Peterbuc,
    Maybe you have to check carefully the up right engine mount Anti-Torque Link. This link is extended backwards from engine mounting bracket (which is over the elastic mounting bracket) to the chassis and usually looks good. To test it, just put your hand on it and gradually increase the revolutions of engine. If this part is the reason of noise, you will feel the vibration (in high frequency) on your hand and the same time you will hear the noise at a specific interval of engine revolutions.
    Following is a diagram for guide. The torque link is the No 5. Good luck and be careful.
    Happy New Year,
    Yiannis
    23/07/11
    0601 01 3480 60A
    FIXING POWER UNIT
    BVM6
    01 1880 A6 01 ENGINE HOISTING HOOK
    02 1880 A7 01 ENGINE HOISTING HOOK
    05 1806 74 01 ANTI-TORQUE LINK
    RIGHT
    SUP LG 163,5 DIAM 52
    06 1803 91 01 SHAFT SCREW
    10X150 LONG 100
    07 1806 70 01 ANTI-TORQUE LINK
    RIGHT
    INF
    08 1803 33 01 HEX HEAD CAPSCREW
    DIAM 10X150-72
    09 1840 46 01 NUT SOCKET
    10 1840 45 01 BOLT PIN
    M12X175-70
    12 1839 E0 01 ENGINE MOUNTING BRACKET
    SUP
    13 1803 C6 04 SCREW CX
    M 10X150-60
    14 1844 93 01 ENGINE ELASTIC MOUNTING BRACKT
    RIGHT
    DIAM 93 M10X150
    15 1812 38 01 ENGINE SUSPENSION FIXING NUT
    M10X150
    17 1813 98 01 ENGINE ELASTIC MOUNTING BRACKT
    DIAM 12,4(2)X10,1
    18 1807 X6 01 ENGINE MOUNTING BRACKET
    LEFT
    INF
    20 1807 V4
    RP 1807 HJ
    01
    01
    RIGHT
    INTM SUP
    21 1803 E7 02 SHAFT SCREW
    M10X125-92
    22 1803 E8 01 SHAFT SCREW
    LEFT
    H EMB M10X125-67AC10
    24 1807 X7
    RP 1807 HT
    01
    01
    RIGHT
    INTM INF
    25 1809 21 01 ENGINE FLEXIBLE-BUSH
    RIGHT
    DIAM 70X10-53
    27 1808 35
    RP 1815 31
    01
    01
    HEATSHIELD SECURING BLOCK
    28 1803 E5 03 GEAR-BOX HOUSING COLUMN SCREW
    M10X150-39 M6X100-19
    30 1890 37 01 ENGINE-G/BOX ASSY IMPACTOR
    31 1891 14 01 ENG-G/BOX IMPACT STRENGTHENER
    70 6923 77
    RP 6923 H0
    01
    01
    SELF LOCKING SELF-TAP SCREWS
    DIAM 6X100-16
    71 6923 78 01 SELF LOCKING SELF-TAP SCREWS
    DIAM 8X125-25
    73 6925 A6
    RP 1803 T7
    01
    01
    SCREW WITH BASE
    DIAM 10X150-80
    74 6936 96
    RP 6936 E3
    01
    01
    SELF LOCKING NUT
    M 12X175-12-24
    76 6949 48 01 PLAIN WASHER
    10,5X65 EP 3
    77 6912 G8
    RP 6925 T7
    02
    01
    SCREW CBLX RDL
    8X125-25
    79 6923 81 02 SELF LOCKING SELF-TAP SCREWS
    M10 X 150 - 75
    80 6924 G7 05 SELF LOCKING SELF-TAP SCREWS
    M 10X150-65
    81 6925 R9
    RP 6922 G8
    02
    01
    DIAM 10X150-55
    82 6935 C9 01 NUT WITH WASHER
    84 6917 A8 01 SELF LOCKING SELF-TAP SCREWS
    RCN M10X125-70AC10
    85 6922 G7 01 SELF LOCKING SELF-TAP SCREWS
    10X150-40
    86 6939 97 02 NUT WITH WASHER
    DIAM 6X100-7-18
    88 6921 37 01 HEX HEAD CAPSCREW
    DIAM 10X150-100
    89 6936 E1 03 NUT WITH BASE
    M10X150
    90 6921 C5 02 TAPER HEADED HEX SCREW
    M10X150-30
    jya likes this.
    Dec 2013
    Nicosia/Cyprus
    9
    I just found the way to "steal-copy" the diagram from Citro.. site and I have posted it on the previous post.
    Sorry guys.
    Yiannis
    jya likes this.
    jya
    jya is offline
    Tadpole jya's Avatar
    Apr 2018
    Melbourne Australia
    26
    Found this helpful old post from citroyannis. Its this anti torque link bush that has gone on my car on the mounting bracket side causing engine vibration.
    2009 Citroen C5 HDI
    Triumph Stag
    Triumph 2500S
    Jaguar S Type R
    Melbourne, Victoria.
    1,390
    It really sounds like a broken engine or gearbox mount to me. That's the usual reason for that type of noisy vibration. And it's a relatively cheap and simple repair too.
    Jul 2017
    Mitchell ACT
    16
    Engine mount rh front or the harmonic balancer pulley
