Coughing Xantia 2.0i 16v
Results 1 to 2 of 2
    Feb 2006
    32
    Default Coughing Xantia 2.0i 16v
    My manual Xantia has developed an intermittent stutter which starts to happen only when the engine is hot after an hour's driving or so. It happens at low to moderate throttle openings and low to moderate revs (i.e. in heavy traffic). Resetting the ECU has not fixed the problem. Various posts here and in the UK suggest either the MAP sensor or the intake manifold temperature sensor as a culprit - does anyone know a way I can diagnose further without going to the expense and trouble of replacing those units in turn and seeing what happens?
    Danny
    '71 R16, died of driver error (mine)
    '69 R16, unwisely traded in for
    '79 Virage Wagon, collided with gentleman driving sideways round the wrong side of a tram
    '76 R16TS, died (and nearly took me with it) of being T-boned by 4WD running red light
    '73 R16TS ('Deidre'), electrics in meltdown Feb. 06
    '81 R18 wagon, gone to another owner
    '97 Xantia 2.0i 16v
    '07 C5 ('Sandrine')
    Don't remind me!
    16,609
    Have a look at your operating parameters on Lexia, there may be some oddness. Best to watch it from dead cold to when the cooling fans come on. Also don't discount the simple but known issue of a dodgy positive cable from the battery to fusebox.
