2003 C5 Sequential shift issue
Results 1 to 2 of 2
    Nov 2013
    Gold Coast
    153
    Default 2003 C5 Sequential shift issue
    Hi,
    When I bought the c5, the shifting pin thing was missing as the previous owner removed it because the car was stuck in P. I ordered the new part and on a thread I found here with images and replaced the pin. Everything seems to be in order except the car will no go into sequential shift. I can move it across into sequential ok, move the lever up and down as if to change gears, but the car stays in drive. Anyone know what else I should look at?
    Thanks,
    Gareth
    Nov 2013
    Gold Coast
    153
    So I took it apart and found what the problem is. Theres a little circuit board on the left where the magnet on the lever engages the sequential shift. This board is damaged as far as I can tell, does anyone know the part number of this board and a cost? I've checked service.citroen.com but it doesn't go into internals of the auto gearbox controls.
