DS 23 EFI issues
Results 1 to 8 of 8
    Kapunda
    493
    Default DS 23 EFI issues
    My 23 has just been awakened from a 5Y rest.While it idles OK and goes well on full throttle inbetween it is very hesitant and nervous.I think it is running too lean(no black deposits on the ex pipes) Fuel pressure looks good.
    I dread pulling the injectors,the rear two are harder to get at than my wisdom teeth.All help welcome.
    Woody
    16,698
    Manifold pressure sensor ?? From memory the DJet doesn't have full load and idle switches like the CX's injection system. The switch on the throttle body sends out a series of pulses from memory. So this would drive the "enrichment" side (like the accellerator pump on your carby). if this was unplugged I imagine it would run as you describe (ie: like a carby car with no working accelerator pump).
    shane L.
    Kapunda
    493
    shane L.
    Thanks Shane,The Djet has a.n idle switch on the throttle body and a separate full load switch operated by manifold vacuum.
    Woody
    16,698
    Thanks,
    It's been years since I looked at mine.
    If you check the manual, I think you'll find the one on the throttle body switch also sends a "sort of" square wave signal out when it's rotated. There may be a broken wire or similar too it. I always assumed this was to richen the mixture when you moved the throttle.
    I didn't realise the manifold pressure sensor was also the full load sensor ... In theory at least that rules that one out.
    10,094
    The manifold pressure sensor and full load vacuum unit are located together on the firewall.
    Maybe, start with checking for any vacuum leaks and cleaning the connectors?
    AAV stuck open? It should be open when the coolant is cold and then close as it warms up and the wax element expands. Perhaps, switch off and test it by blowing through the air hose to/from it and see if it changes between cold and normal operating temperature?
    Do you think the pressure regulator is still OK? The rubber diaphragm may be suspect.
    Los Angeles, CA USA
    1,955
    Did you check the airbox for rat nests?
    Via the aussiefrogs App
    Kapunda
    493
    Thanks David,I've checked the fuel pressure. I dispensed with the unreliable AAV some time ago and now have a manual one.
    So out come the injectors.
    Woody
    Dec 2010
    463
    I'm thinking before you pull it apart make sure the multi segment switch is doing it's thing and enriching the mixture as the throttle is opened... The way this works is that between fully closed and wide open it should give all the injectors an extra 20 opens. To test that this part of the system is working switch ignition on without starting, get your head in the engine bay, and open throttle with your hand slowly. You should hear 20 injector clicks as you open it and no clicks as you close it. Also, really does also sound like it could have a vacuum leak causing this stuff.
