BX hydraulic pump needed
Results 1 to 7 of 7
  • 1 Post By David S
Thread: BX hydraulic pump needed
    Member twistedeez's Avatar
    Mar 2011
    Byron Bay
    114
    Default BX hydraulic pump needed
    Chasing a pump. Particularly those in the Gold Coast - Brisbane area. Will pay $.
    Does anyone know what causes them to start rattling loudly once revs are above 2000? No noticeable noise at idle. Still pumps up the car but it does seem fractionally less responsive in steering and rear suspension.
    Can they be rebuilt at home?
    Out of the 1992 Saab 900 turbo and into
    1989 Citroen Bx 16v
    Mar 2011
    Byron Bay
    114
    Should have posted in parts wanted. Oops.
    1989 Citroen Bx 16v
    10,094
    Are you certain there is no air leak in the pickup line? That might cause extra noise and poor performance.
    UFO likes this.
    Mar 2011
    Byron Bay
    114
    No I'm not certain. But I'm certainly going out right now to have a look.
    1989 Citroen Bx 16v
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    417
    Check the tension on the pump belt as it needs to be REAL tight.
    Via the aussiefrogs App
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
    canberra
    300
    What sort of fluid are you using..I have a theory that they start rattling like a bucket of hammers if you use an auto transmission fluid.. I had a rebuilt pump and low km pumps go more rattly after I started using an ATF..
    And not sure if its my imagination but other pumps I've had seemed to get noisier with ATF.. I always got excited by the possibility that it may be just air in the system, but never to any avail.. all connections tight.. same din..air should not get trapped as it will naturally purge itself if all air ingress is sealed...
    The worse offender is the GT that, as you describe, rattles terribly at about 2000rpm..let me know if you find a magic pill..
    Mar 2011
    Byron Bay
    114
    Ok ok who's got the red face. Er an interesting question but the fluid is LHM. Only replaced about 4 months ago. Turns out it is the bearing in the tensioner pulley. Bit of grease and it will be good for a while. Any one got a spare pulley?
    1989 Citroen Bx 16v
