Xantia Front Brake Calipers
Results 1 to 7 of 7
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    381
    Default Xantia Front Brake Calipers
    Brains trust. Best I could find on workshop manuals was C5 which appears to have much same set up as Xantia.
    Issue - did the right thing and bought a brake piston retraction tool and buggered if I can get the piston back in to accommodate new calipers. Have depressurised the hydraulic system. Even loosened the brake feed hose a bit.
    Am I missing something here?
    The piston rubber boot is knackered on the outer side and am wondering if there could be a bit of rubber floating around inside there?
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    A brake piston retraction tool? On the Xantia and BX you have to screw the piston back into the calliper to fit new pads
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    CitroŽn Tragic UFO's Avatar
    9,786
    They screw in clockwise.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,473
    The ideal tool is a square section rod that fits into the groove on the piston. I don't have the ideal tool but find a flat screwdriver does the job.
    John
    Newcastle
    2,757
    Hi
    On the C5 front brake pistons one screws clockwise(left I think), the opposite one screws anti-clockwise. I had to tap it a bit as I screwed to get it to move in ! Two person job !!
    If you have the caliper hanging on the bottom screw/pin and folded out, the direction of screwing holds the caliper in the folded out position so it will stay there OK while you do it.(C5)
    The boot rubber may be jammed between the piston and the cylinder but cannot get "Ônside".
    Good luck
    Apr 2005
    381
    Thanks for the input everyone. All solved. They screwed in clockwise. New brake pads make an incredible difference. ABS light on the dash was glowing for a bit but has since sorted itself.
    '73 & '74 GS Break
    '00 Xantia Break
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    417
    Glad to hear it's all resolved
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
