Citroen CX inlet Manifold vacum leak and heater question
Results 1 to 16 of 16
    Sep 2013
    nz
    69
    Default Citroen CX inlet Manifold vacum leak and heater question
    Hi All,
    I seem to be finding more and more questions than answers in my quest to get the CX road worthy.
    Upon searching for a LHM leak around the brake valve a came across a small vacuum hose that is connected to the bottom of the inlet manifold
    this is just sucking the atomsphere. Does this need to be connected to something or am i missing something.
    Also, on the heater/cooler ducting someone had screwed a plate on the vacuum operated valve moving between cold air and something else. What is the something else for?
    And upon all that i think i found the problem of the leak. The oil level reader pipes to the back of the block were frayed etc. after some huffing and puffing these were snipped and fixed. if not this would leak LHM would it not.
    Thanks again for all the Aussie frogs help. Ben
    9,670
    Not sure about the vacuum lines, but you can have a significant LHM leak from the LP return piping from the brake valve. There is a T joint there that splits. Have a look at it from the wheelarch, making sure the car is supported properly. I once, and only once, gave myself a big scare under a CX by pulling on the height corrector linkage - asking ... Now what does this do? - then the car dropped onto the wooden blocks I'd placed under it!
    Fellow Frogger! Fingers's Avatar
    Old Junee NSW
    581
    A timely remind to read the sticky regarding working on hydraulic Citroens......
    10,705
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    9,670
    Absolutely!
    What one does when one is curious and one doesn't really know what one is doing with the benefit of hindsight!
    Maybe, benvv could post a few pictures of the parts being asked about? It's common for people to add vacuum taps and solenoids to cut off the flow to the heater in summer, so what's there may be part of that.
    10,705
    Absolutely!
    Yes, I agree totally, to both sentences. "Curiosity killed the cat" it is said! And yes, photos would help, as I didn't understand the question.
    Renault 4CV 1951
    Renault R8 1965
    Sep 2013
    nz
    69
    please see attached the blower intake and how there is a steel plate screwed over the vacuum operated valve. is this the hot air intake that has been blocked up or?
    the main query is what is this vacuum line for? i have taken another picture of an intake manifold to highlight where it is connected to.
    you can see the small nipple where the vacuum line is connected to.
    all comments and assistance greatly appreciated.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,025
    That pipe under the manifold is a petrol drain. It is calibrated to only admit a slight amount of air into the induction system. It usually has a tube connected to it that passes any flooded petrol to the under side and onto the road.
    The vac capsule on the side of the heater box should connect via a vac line to the heavy vac line that comes from the console lever closets to the drivers seat. It controls the air re-circulation of the ventilation and air con system.
    Often these vac capsules have a perforated diaphragm and are inoperative. I built one good one up from several different units that each had different faults.
    I have not seen the metal plate before. Maybe some one has performed a repair?
    Cheers Gerry
    Melbourne, Victoria.
    1,388
    I once had a CX and had that intake unit out of the car.
    I think that metal plate you have there is original, but it's been glued shut somehow. It's supposed to open and close , remote controlled by that little air servo, connected with rubber tubing from the control console.
    If you want to restore it to it's former condition have a look at how it's been glued shut, and cut through the glue. The top of the flap should have a rod which the plate is hinged on. It should open and close.
    That's a known issue with that CX air flow design. Even with the heater tap closed , air coming through the air intake on those cars is always warm. On hot days it's VERY warm. The heater is great in winter, but it's not a very cool car in summer.
    Cheers...George 1/8th.
    16,334
    Quote Originally Posted by benvv View Post
    Hi All,
    It sounds like you have found the manifold drool tube, leave it unblocked. The oil level gauge will not leak LHM, I have never seen a working one, it's not a part of the hydraulic system. If you wish to dismantle the car back to it's component parts, you could in theory refill the level gauge with LHM so it works. Unless you remove XM dashes just for the enjoyment of it, you'll not get the level gauge working.
    Degrease the entire area with a pressure washer and degreaser and put the car up on ramps, you should them be able to see where it's dripping from. It's likely nowhere near the spot it drips from the car from, the LHM will be running down lines, across cables, down cross members and often on a CX drips from the front height corrector. It is almost unheard of in my experiance for it to be the height corrector that's leaking, it's always something above it.
    16,334
    The metal plate is blocking off the recirculation duct. The car must not have air conditioning, you don't get the recirculation duct unless the car is air conditioned.
    Sep 2013
    nz
    69
    thanks all for the prompt answers.
    it seemed nonsensical to have a drip tube on the manifold but some how it starts to make sense. yes there is a tube attached to it.
    the blanking plate was screwed on, so presumed it was added after produtcion. the vacuum valve seemed to hold suctions so presumably it still works.
    However with the car running i cannot seem to get a vacuum from the tube that connects to the valve. The tube from the carb is connected so presumably there is an issue with the lever in the cabin. Any thoughts or observations.
    Regarding the leak, got a whole lot of degreaser so on to the area to see if can ascertain a leak. Then took it for a 10min drive to the rust man. no sign of a leak. i think the testing officer is having me on, or the drip was a hangover from the octopus leak that i remedied weeks ago.......
    thanks again ladies and gents.
    Oct 2011
    Toowoomba
    647
    Cats don't have to be curious to get killed by Citroens, just to be asleep when the suspension sinks down.
    Sep 2013
    nz
    69
    Hi again all,
    1977 CX 2400 Pallas
    On the wiring loom i have found a lead not connected to anything that seems to have sometihng to do with the heating veneliation system. Turning the heater controls changes the voltage present between 5 to 12 volts.
    What would ti be for?
    Feb 2013
    451
    (The vacuum should work when you pull the heater level all the way back to cold (re-circulate) I can hear a faint buzz from the controls when doing this and the vacuum starts)
    Via the aussiefrogs App
    Feb 2013
    451
    Hi again all,
    1977 CX 2400 Pallas
    This sounds like your interior fan? The resister would change the fan speed therefore the voltage. If it changes on the heater control then this lead would activate the vacuum actuator for the recirculating air flap
