DS rear brake
Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By David S
  • 2 Post By UFO
  • 1 Post By David S
  • 1 Post By IE23
  • 1 Post By richo
Thread: DS rear brake
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default DS rear brake
    I noticed the rear brake has some green wetness.
    What should I check? An easy fix?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    10,128
    The wheel cylinder inside the drum. It's a normal wheel cylinder but uses LHM instead of brake fluid. It probably needs a seal kit.
    Mort Subite likes this.
    CitroŽn Tragic UFO's Avatar
    9,791
    Quote Originally Posted by IE23 View Post
    Your bank account balance - quickly before the Citroen eye sneaks a peak.
    David S and Mort Subite like this.
    10,128
    You might start with the seal where the pipe enters the cylinder. Is it wet? Or the bleeder nipple?
    Jan 2011
    749
    Too late!! Direct access like 3 intravenous feeds. A necessary life support system. A friend often asks me "which patient is it today?"
    UFO likes this.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    Jan 2011
    749
    its leaking from the bottom of the drum as far as I can tell. So sounds like a seal kit is required?
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,406
    Yes, you probably need a seal kit. Remove the drum and have a look. It's not hard. Remove road wheel. Undo the two screws that hold the drum to the hub. Pull off drum. You may need to free the drum. Whack it with a rubber hammer if you have to. If you don't have a rubber hammer then hold a piece of soft wood to the drum and whack that. Start gently. Whack the side of the drum, at various places around its edge. Do not lever the drum, you will bend or break something. Once you have the drum off any leaking LHM will be obvious.
    If the wheel cylinder is leaking I would suggest you do up both rear brake cylinders.
    Roger
    Jul 2005
    Feilding New Zealand
    41
    don't forget to back the brake adjuster off first
    D rear brakes are some of the simplest to work on. no millions of springs and levers like most rear drum vehicles have with the handbrake incorporated.
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,446
    DO NOT loosen the locking plate or move the brake shoe cam adjuster unless you have a brake lining centreing tool.
    Without this tool, you will more likely than not, if you move the cam adjusters, put the linings out of adjustment.
    You can easily remove the shoe springs and access the wheel cylinder, without disturbing the shoe adjustment.
    Most D's I've seen have the rear brake shoes out of adjustment. Without the tool it's a hit or miss adjustment at best.
    UFO likes this.
