Changing oil in AL4
    Nov 2013
    Gold Coast
    153
    Default Changing oil in AL4
    Found this guide which is really helpful and hoping to do this on the weekend.
    Please re-post C5 AL4 transmission refilling guide
    Just one question. It says to refit the drain plug, fill, then remove the centre drain plug and let the overflow spill out. I can find the drain plug and the fill plug, but not sure where the centre drain plug is?
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    It is in the drain plug, it just opens up hole at the bottom of the tube that is part of the drain plug
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Don't remind me!
    16,609
    Jason Hantos recently showed me a later C5 drain plug. It has no centre portion, instead favouring a beige plastic insert that functions as level tube and is unscrewed for draining (by poking the appropriate size of Allen key up there). Had only seen this before on VAG auto boxes.
    Nov 2013
    Gold Coast
    153
    Ah, thanks guys
