C4 Boot has a mind of its own
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    467
    Default C4 Boot has a mind of its own
    Hi all
    my C4 VTR Coupe has started unlocking the boot when I use the remote.
    has anyone else experienced this phenomenon
    Not sure if I like it !
    10,102
    It's probably due to some broken wires in the boot harness where it has the convoluted boot between the tailgate and body. Takes a while to repair, so if that's the cause you might ask about a new harness.
    Aug 2005
    Merimbula, NSW, Australia
    323
    If it's the same as my C5, the plastic part that your fingers press to activate the microswitch needs some lubrication. On my C5, it siezes every now and then which causes the microswitch to be kept on.
    You should be able to hear an audible click on & off if it's working correctly.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    Feb 2011
    brisbane Au
    940
    Quote Originally Posted by dieselman View Post
    Mechanical opening lever on the outside of the boot lid, that's the beauty of the early C5 hatch. Some cars just have too many electrical gizmos.
    Feb 2013
    455
    Yes this is a known issue. Check the UK C4 owners forum. Only occurs with the two door model with the wiring shorting out due to the wear of opening & closing bending the harness etc.
    Via the aussiefrogs App
    don
    don is offline
    Mayfield Newcastle
    467
    had a new harness fitted on international recall last year
    Guess Ill call the dealer that fitted it
    a
    Quote Originally Posted by Jinandfonic View Post
