C5 open window in ecomomy mode.
    Tadpole smatic's Avatar
    Oct 2005
    bacchus marsh
    18
    Default C5 open window in ecomomy mode.
    Hi all. i need to close the drivers window on my C5. it has put itself into economy mode (while being towed home, hence the open window), so nothing works. I would like the window to be closed as the car is now parked on the street and as the engine is failing to proceed, i can't follow the normal proceedure of "start the engine to get put of economy mode" So you can see my dilema.
    PvA
    C5,
    2cv
    minimatic
    moke,
    another moke
    Vermorel
    8,159
    Quote Originally Posted by smatic View Post
    I'm not sure why you can't turn the ignition key and use the switch, must be something I'm missing with regard to 'economy mode'?
    Have you tried using the key plip? We often use ours to close windows after a drive. The window button on the early cars is the lower of the three - not sure which model you have.
    08 C5 X7 HDi very Noir
    Oct 2005
    bacchus marsh
    18
    2003 hdi. when in eco mode nothing electrical works except central locking and engine start. forgot to try the windows button on the remote!!. i've only had the beast a couple of months. I have had success though. I've repeatedly tied to start it in the vain hope it would actually go. crank crank cough splutter off on, crank crank cough splutter off on, crank crank cough splutter off on, crank crank cough splutter off on, crank crank cough splutter off on, ooh look! eco mode has switched off. the xsara does it to if you sit listening to the radio for to long with the engine off, but i've just started it as it hasn't had an engine problem!I didn't actually know what eco mode was until today. NOW i do!
    PvA
    C5,
    2cv
    minimatic
    moke,
    another moke
    Vermorel
    8,159
    Excellent, sounds like you've had a win - windows up and locked?
    9,670
    ... engine is failing to proceed, ...
    Have you figured out why it won't run? As a start, you might check for a burnt pin connector on the engine bay relay/fuse box as the early HDi has an electric fuel pump that can stop working for that reason.
