Xantia Reverse Lights
Results 1 to 15 of 15
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    372
    Default Xantia Reverse Lights
    Something bit dicky happening with the Xantia. No reversing lights, top brake light not working, number plate lights very dull and hatch brake lights not working.
    Checked bulbs/connections up back, all appear good. Fuses all look OK.
    Any suggestions folks?
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,282
    Sounds like an earth wire for the the tailgate has come loose or broken.
    Via the aussiefrogs App
    406 D8 V6 manual
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,145
    All the cabling from the car goes up the C pillar on the drivers side to the hatch.
    If you remove the trim panel to get this:
    If you remove the lower black cover you get this:
    The lower cabling operates the lights NOT mounted on the hatch.
    John
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    What happens when the blinkers are on one side and then the other. If other lights flash in union or opposition you definitely have an earth problem
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Apr 2005
    372
    Many thanks everyone. Appears that a lot of action happens near the hinge.
    Just goes to show you need to give 'em a bit of slack. Is the green earth? With my avatar you think I should know this.
    Attached Thumbnails Attached Thumbnails Xantia Reverse Lights-2013-11-10-16.08.55.jpg
    '73 & '74 GS Break
    '00 Xantia Break
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Similar thing happens in the drivers door
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,208
    Wiring is different (bits on different sides) between series 1 & 2 sedans, so may well be also with the wagons.
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    JBN
    JBN is offline
    8,145
    Quote Originally Posted by sparkey View Post
    I would just join both ends of the green wire together and both ends of the red wire together.
    But, hey, I'm not a sparkey so I have no idea what I am doing.
    John
    IWS
    IWS is offline
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,294
    Well yes, with that avatar one would assume you knew something about wiring ...
    From my limited (and I stress limited) understanding, green wire is not generally an earth in auto-electrical wiring. Ground, in the case of auto electrics, more likely brown or black I believe. Experts - please correct here!
    But I guess, as JBN suggests, safe to just reconnect the existing (but broken) wires.
    Ian.
    Faulconbridge
    2,362
    Icon14
    John
    Excellent John,you are the only one;when a question is asked,races out to your car,rips the offending part apart,takes photos and supplies the answer,Andy.
    JBN
    JBN is offline
    8,145
    Actually, I drive my car partly stripped as I am a a true believer of Citroen reliability.
    John
    San Diego, California, USA
    3,508
    Quote Originally Posted by IWS View Post
    Ian.
    My understanding is slightly better. If you think ground-wire-is-green is confusing, try an early Bosch K-Jet fuel injection system. All wires on that one are white. A Citroen D doesn't care what color wire- it all depends on the color sleeves- and the black often stands in for battery +! Black or brown for ground is the international norm. But you need to remember the French march (well, did march) to their own drummer.
    On many Peugeot products, the ground was green with a yellow tracer. However, John has the point- just reconnect like with like. My suggestion though would be to not just resplice right at that point. You're begging for another failure. I would replace the wire down into the body cavity and on up into the deck. I know that's a pain to do, but your repair will last. I would also be very carefully checking any other wires that go through that rubber boot.
    Sep 2003
    North Parramatta
    3,988
    Colours are irrelevant in my experience on those era PSA products. It's usually all about the little codes printed on the insulation.
    Earth wires usually have codes starting with M, like MC10 or MC11, M009, M162, etc, for example.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,892
    Icon11
    I just had to do a bodgy on my 1997 Xantia wagon tailgate lights. Faults - intermittant rear wiper, LHS parking light out, centre bar stop light out and RHS number plate light out but bulbs in all OK. LHS light cluster has one connector which goes through flat cable to the RHS cluster so nothing to look at there. RHS cluster has three connectors, the one coming from the LHS cluster, another three wire one that has a big fat yellow wire (which turned out to be an earth) and a two wire connector with two thin green wires one of which was at +12V and the other open circuit. So I did some wire tracing and found the line going to the LHS parking light cam from the open circuit thin green wire. I then took a punt and shorted the two green wires together and all the 'dead' lights started to work. So I ended up just joining these tracks on the RHS light cluster with some wire that had a 3A fuse in it and put it all back together. So now all the lights work but the windscreen wiper is still dead. Sometime I will have to have a look at those two sheethed cable looms that come out at roof line and go into either side of the tailgate.
    So think yellow for earth and thin green for +12V in the Xantia Tailgate.
    Ken W
    Melbourne, Victoria.
    1,388
    Hi Froggers,
    my first car was Italian. Just like their motorbikes in the 70's, any wire could be any colour, regardless of what the wiring diagram said. Before this I had mostly worked on Japanese electrics which always stuck strictly to the code, so I was astonished. I know on my Xantia that black is usually the Earth, and red is usually positive. These codes are pretty standard, and I find the loom is usually as per the wiring diagram in the workshop manual.
    Cheers....George 1/8th.
