No 1st gear citroen id 19
Results 1 to 12 of 12
    Nov 2011
    87
    Default No 1st gear citroen id 19
    Looking for advice on why car won't engage first gear - gearstick moves into first but when clutch is released no movement -all other gears fine- 1960 id19 thanks in advance
    Via the aussiefrogs App
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    792
    Have you adjusted clutch lever clearance on Bell housing? Other gear ok?
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    Ici.
    2,525
    Plus the cable could have split in two!
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,025
    Could the problem be internal? The selector fork may be loose on its rail! Does it engage reverse?
    Cheers Gerry
    Nov 2011
    87
    Thanks for the comments - besides first engages in all gears including reverse - might have to take top off gear box and have a look
    Jan 2011
    netherlands
    45
    Quote Originally Posted by andyk View Post
    yes take off topcover. 1st and 2nd gear are with one fork on one axle. So if you can engage 2nd gear, fork should be ok.
    cheers,
    Harry Martens
    VERSNELLINGSBAKREVISIE
    Nov 2011
    87
    Cheers Harry - might have a look tomorrow
    May 2011
    SOUTH MORANG
    792
    Yeah, please post photos when you done it. I have the same car and I would like to have idea about any kind of faults.
    16,333
    I would be looking for something snaring the selector rod that runs from the gearshift inside the car down to the gearbox (I would have expected you to be also missing 3rd if this was an issue ).
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    641
    The selector cable is a bit more than just a cable. I once had the flat section within it fracture allowing the selection of 1st and 2nd but not 3rd or 4th.
    Start with where the cable connects to the box lid. The key that locks the cable to the box can slip out of its holder allowing the cable to move. Mine is bound with electrical tape and that fix works well.
    Citroen Car Club of New South Wales member.
    My Citroen ID21F can be seen here http://www.flickr.com/photos/frontdr...7605999522616/
    Nov 2011
    87
    Thanks guys I'll hopefully get onto it this arvo
    Nov 2013
    Veenendaal Netherlands
    1
    No 1st  gear citroen id 19-dsc02299.jpgAt first you can try to disconnect the tube and cable from the bolt plate, then turn the bolt plate anticlockwise, if the car is in first gear now, then there is something wrong with the tube or cable.
