C5 Aisin Warner 6 speed automatic - Page 2
Page 2 of 5 First 12345 Last
Results 26 to 50 of 101
Like Tree51Likes
Thread: C5 Aisin Warner 6 speed automatic
  1. #26
    Fellow Frogger! Meggsy's Avatar
    351
    try A & B transmissions in Melbourne( Dandenong) they do the repairs for Peugeot Australia always found them top rate
    antonio likes this.
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
  2. #27
    Don't remind me!
    16,609
    I personally wouldn't piss on them if they were burning.
    shanadoo, dimistyle and antonio like this.
  3. #28
    Feb 2011
    brisbane Au
    927
    Thank god for that, because I'd be there watching and holding the petrol can.
  4. #29
    Nov 2013
    NSW
    39
    does anyone think there would be any harm is putting a lucas stop slip additive to the box ?
    https://www.lucasoil.com/products/di...smission%20Fix
    shanadoo likes this.
  5. #30
    Oct 2013
    Epping
    108
    Don't use stop slip or any additive because it's full of zinc to try to soften the seals but it really turns them rubber o ring s to jelly that's an old thing invented before the 80s and hasn't changed much
  6. #31
    Nov 2013
    NSW
    39
    thanks. i tried getting a valve body rebuild but did not work. this is a great video showing a similar model box being dismantled. a common theme he repeats is that there's often more wrong than the valve body. keep this in mind when considering between a valve body and complete rebuild.
    www.youtube.com/watch?v=PrAe4XBzENc
  7. #32
    Dec 2010
    225
    Given my aviation experience and the fact that oil in a/c hydraulic systems was regarly changed I would so that changing oil in a modern transmission should go a long way to prolong its life given this is why we change engine oils both deteriate and im sure as someone pointed out that ford product was same as peugeot maybe we need a sticky to highlight replacements to OEM
  8. #33
    Dec 2010
    225
    Given my aviation experience and the fact that oil in a/c hydraulic systems was regularly changed I would say that changing oil in a modern transmission should go a long way to prolong its life given this is why we change engine oils, both deteriorate and I'm sure as someone pointed out that ford product was same as Peugeot maybe we need a sticky to highlight replacements to OEM
  9. #34
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by frenchtranstech View Post
    Post is a bit old for reply, but for what it's worth here goes. There are no rubber O rings or seals, they're made of a whole lot of different man made compounds, most of which actually respond quite well to Lucas products. Have used Lucas for many years and wouldn't consider anything else because in my book there isn't anything else. It really works well, stops the piston and accumulator seals from hardening, keeps those damn electro valves nicely coated with slippery stuff and usually you find the trans running much cooler. It's the piss poor transmission oil which does the damage in the long run.
  10. #35
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by haydent View Post
    Thoroughly recommend, but after you correct the problems. Too many people think that gearbox internal problems can be rectified by a can of additive.
  11. #36
    Aug 2002
    1,290
    I read these posts and continue to wonder why so many folk buy automatics.
    No doubt there is a good reason? We've just avoided them altogether.
    And then there is the lovely dual mass flywheel to cause grief to the manual driver trying to avoid the issues of the automatics. That is assuming you have the choice in the first place.
    The automatic in my 2005 Statesman did not miss a beat in the 130000 that I had the car for and the one in the 6.0 litre Caprice is still very happy after 153000.
    The zf4hp struggled to get to 100000 on a regular basis.
    Have been considering a 508 gt to replace the Caprice but uncertainty over the auto with no manual option is really clouding the choice, might just hang on to the comfort space and grunt offered by the big limo.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
  12. #37
    Dec 2010
    Mirboo North
    158
    So just to get a clear understanding of the situation - if my AM6 box has had the oil changed and it's still operating perfectly at 86,000km, adding the Lucas Transmission Fix would be a good preventative measure? The only product with 'stop slip' in its name that I could find was for power steering fluid, so I'm guessing this is the product to use for the AM6:
    Lucas Transmission Fix is a non-solvent formula that stops slip, hesitation and
    rough shifting in worn transmissions and completely eliminates most seal leaks.
    Use in any transmission for preventative maintenance.
    Use also in light duty manual transmissions to increase shifting ease and transmission life.
    KEY BENEFITS
    • Contains no solvents
    • Lowers operating temperatures and stops foaming
    • Can be added to existing fluid without draining any out
    • Effective in an extremely high percentage of cases
    PACKAGING
    #10009 - 700ml Case of 24
    Cheerio,
    Geoff (in Mirboo North)
    1994 405 SRDT white - (free to a good home, unreg. & needs injector pump re-fitting)
    1997 Toyota Hilux Surf
    2007 Citroen C5 Hdi Wagon
    2003 Merc Vito 112Cdi
    non-sequitur - 1951 Hudson Pacemaker brush-painted matt black!
  13. #38
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    If it ain't broke, don't fix it
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
  14. #39
    Dec 2010
    Mirboo North
    158
    Quote Originally Posted by Greg C View Post
    Sadly, that doesn't seem to work too well with these modern 'sealed for life' auto boxes. I've heard of suspiciously too many failures, both with euro ZF boxes and these asian types. Anyone got experience to offer on my question?
    Cheerio,
  15. #40
    Sep 2003
    North Parramatta
    3,997
    Yes - if it ain't broke, don't fix it.
    Put another way, no one comes to a forum and tells people about how their gearbox is not broken.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
  16. #41
    Dec 2010
    Mirboo North
    158
    Quote Originally Posted by SLC206 View Post
    haha Simon - perhaps I should clarify by saying I'm not coming on the forum to tell people that my gearbox is working perfectly - as if anybody would care. I'm asking for specific information about a Lucas product's suitability to help get longer life out of this box. Let me put it another way - if it ain't broke, you can't fix it even if you want to, but you can undertake preventative maintenance such as the more frequent oil changes that Greg C recommends from his experience. I'll take your comment to mean you have nothing to add in terms of what might extend the life beyond the 'official' service procedures? Perhaps I should have asked Shanadoo in a PM since he seems to have experience with these types of boxes and that Lucas products will help.
    Cheerio,
  17. #42
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by electroboy View Post
    That's my point - don't add anything
    Regular oil changes would be my advice too, however most people only seem to change the oil when the gearbox has already developed an issue.
    Simon
  18. #43
    Feb 2011
    brisbane Au
    927
    But try to prevent it from breaking in the future.
    electroboy likes this.
  19. #44
    Don't remind me!
    16,609
    Why be proactive when you can bleat on the internet instead?
  20. #45
    Oct 2013
    Epping
    108
    I'm the Chairman of the VACC auto trans category and we are always thinking of ways to educate the the public to regularly change the transmission oil.Thats the only way to prolong the life of the transmission.
    electroboy, Greg and antonio like this.
  21. #46
    Dec 2010
    Mirboo North
    158
    After replacing the valve body with an OEM new one (from the UK, same supplier as Addo used IIRC) my AM6 has been behaving perfectly.
    Before replacing the valve body I had 'changed' the fluid twice (but not prior to 80,000km) and tried additive from Lucas, which really seemed to do little more than delaying onset of shifting problems as the fluid heated up. Obviously the wear and tear in the valve body (bores?) was already underway before the fluid was changed.
    Shame that Citroen don't recommend sensible fluid change intervals, but I guess Citroen is not the only guilty party - the 'sealed for life' transmission caper seems to be little more than a BS story to sneak through EU emissions regulations. They know most autos will get through the warranty period before gear changes go bad.
    Research told me it was perfectly fine to use non-Citroen fluid (I used Toyota fluid, the one they use in the same gearbox). Topped up an extra litre after setting level at 74ļ. If I'd followed the Citroen refill procedure I would have to wait for it to cool to 60ļ and then just top up half a litre. Then told the thing it had new fluid, set neutral position, persuaded it to do a 'full re-program' and went for a lovely drive.
    In between dodging wombats I was watching the gearbox temp top out around 81ļ with no hint of shifting problems. Cheap repair, valve body cost around $700 landed from UK, fluid was around $80 and I have sufficient for another fluid change in 20,000km from now.
    New Pirellis go on today so hopefully we'll enjoy many miles more in this car. I like it a lot!
    P.S. I also just want to say thanks to those who have contributed good info on these Aisin-Warner gearboxes over recent years - especially to Addo, but also thanks to others. Anybody contemplating a DIY valve body change in the AM6 box, feel free to PM me for more details.
    turnbull151, SLC206 and antonio like this.
    Cheerio,
  22. #47
    Jul 2015
    Ipswich
    49
    Well, when I bought my C5 X7 at 105km I bargained with the dealer and any servicing they would pay 50% of. After the timing belt, water pump, coolant, pulleys and tensioners I also go EUROSERVE to do a service on the transmission. Talking to the mechanic he mentioned that Citroen say the box is sealed for life but Puegeot have a service kit for the same transmission. Now at 130,000km and zero issues.
    I use a local Future Automotive for minor services and take it to Euroserve for major jobs. FYI I bount this C5 from a Volkswagen dealer and the comment from the sales man was that the Citroen would be more reliable than the VW....and he's a factory trained technician from the UK>
    Hmmm....
    antonio likes this.
  23. #48
    Dec 2010
    Mirboo North
    158
    Quote Originally Posted by NigeltheC5 View Post
    Hmmm....
    Interesting Nigel, do you know what Euroserve did in their service on your transmission?
    I wonder what the Peugeot service kit for the transmission includes...perhaps seals for the filler & drain plugs along with some fluid? Hmmmm...I might have to ask a pug mechanic about this.
    Cheerio,
  24. #49
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Guys,
    First there was the DS Borg warner, and lots of problems. I would say there wasn't a DS that got through warranty (12 months) without the gearbox removed at least once. Some were 2 & 3 times.
    In hindsight, most of the problems was poor assembly by Borg Warner?
    Citroens autos after that were ZF, and very reliable. Problems towards the end of their life was generally traced back to never changing the oil.
    PSA , Renault & Siemens thought they could build a better box, so enter the AL4. This isn't a bad box like the BW, but it was eventually used with engines in the C5 beyond its capacity. In these situations it was very problematic, though some units have given a very healthy life. Not changing the oil certainly added to the problems
    The present auto is the 6 speed Aisin (not Aisin Warner). This is an excellent unit and is generally very trouble free, so long as you change the the oil. Yes there are some that have valve body problems, and it is an expensive fix, but they mostly give a very trouble free life.
    Our old 2006 C5 HDI has now done 288,000 ks, and the gearbox hasn't missed a beat, but the oil is changed regularly, and filled with Nulon Multi purpose Full Synthetic AT oil only.
    My experience with the AM6 gearbox and the valve body problems is that a reconditioned valve body doesn't resolve the problem. Continental Cars did use a few reconditioned units, but continued to give problems, so they will only use a new valve body now.
    I think that says it all!
    One thing to note is that if you drain the oil through the level / drain plug, you will only drain about 3 litres. I've seen where some transmission repaired suck the oil out, but i'm a bit skeptical that you can drain the entire contents?
    Best regards,
    Greg
    We Have:
    We Had:
  25. #50
    617
    Hi Guys,
    Best regards,
    Greg
    We Have:
    We Had:
