2CV Rear Door Has Dropped Down
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    191
    Default 2CV Rear Door Has Dropped Down
    Would a 2CV Guru kindly advise how to lift a rear 2CV door that has dropped too far south in its hinge. If I lift the door a little it closes fine. How can I keep it at the correct height in the hinge?
    Albany WA
    249
    Quote Originally Posted by Inspector Clouseau View Post
    Keep lifting the door a little. It wouldn't be a real 2CV if it all works perfect!
    Feb 2003
    Sunny Melbourne
    79
    Quote Originally Posted by Winkbul45 View Post
    the wisdom of experience, so very true
    Jul 2003
    317
    Hi inspector,
    I had this issue when I converted my front doors to suicide doors using the same hinge design as the rear...
    I over came the issue by welding a steel rod into the botton of the B-pillar hinge at the required height. I had access to the bottom of the B-pillar hinge where you will not...
    But! You can find a peice of steel rod that will fit into the round profile of the B-pillar hinge, cut it to the required lifting height and insert it into the top of the hinge, then insert the door and it will aid it in sliding down.
    Hope that helps!
    Harley
    Dec 2002
    North Coast NSW
    191
    Thanks Harley - that sounds like a feasible fix.
