CX spheres
Results 1 to 12 of 12
  • 1 Post By David S
Thread: CX spheres
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default CX spheres
    I'm planning to replace the two accumulators in the lower engine bay. At least I think they are both accumulators, one main and one brake? The main is leaking and the brake one looks ancient. I'm planning to order them from CXBasis, what seals should i also order so that I have a complete set of replacement parts?
    or is there a better place to purchase the right set?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Citroworld, about 30 Euros per sphere + reasonable postage. Cheap as chips.
    Seals usually come with the spheres, again, they're only a couple of Euros each, same as a D series seal.
    Feb 2013
    458
    John at DS motors (BNE) just overhauled my main accumulator at a very reasonable cost. He has heaps of good spheres available too.
    Via the aussiefrogs App
    16,757
    You can't overhaul accumulators (unless they are DS ). All they can do is regas them and possibly spray some shiny paint on the outside. I suggest new spheres is by far the best option for accumulators, especially the brake accumulator. They aren't expensive like they were in the past.
    Jan 2011
    749
    Can you clarify for a novice please;
    the Main sphere = acculumlator sphere?
    the Brake sphere = the same as above?
    so I order 2x accumulator spheres?
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    16,757
    yeah an accumulator is an accumulator regardless of where it's fitted. If they are spec'd/listed differently, the pressure will just vary slightly.
    Jan 2006
    1,448
    Here are some really cheap welded (one piece) spheres, I can't believe they're so inexpensive.
    Dunno about the freight from France, but the price is right!
    balais essuie glace, bougies prechauffage eBay Boutiques | pieces automobiles
    Seems like all models catered for.
    10,196
    They'll likely be the IFHS variety. Welded accumulators are nominally filled to 62Bar when new. Accumulator spheres have no damper in the threaded end, but that's also true of Hydractive stiffness regulators. On a CX, it takes a little bit of work to get at the main and brake accumulators down the bottom, so not fitting new items is probably a false economy.
    UFO likes this.
    Feb 2006
    Brisbane, QLD, Australia
    515
    I recall (grom discussions with Steeley) there are dual diaphram versions as fitted in the late Xantias available. They would last much longer. Changing accumulators can be awkward operation in some models so if there was a long lasting sphere that would be great.
    CX Register
    10,196
    Quote Originally Posted by kimmo View Post
    Yes, they are painted grey, but in the old shape, unlike the flatter C5 spheres.
    Feb 2013
    458
    Oops, I meant the main regulator was rebuilt.
    11,307
    Now that IS interesting. Do we know where to get them and what precisely to ask for?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
