Gs pallas
Thread: Gs pallas
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    377
    Default Gs pallas
    hi people
    can anyone assist. is anyones aware if the low pressure "RUBBER" pipes in the photo are the same as any other model of a citroen.
    i would like to replace these with the same however these parts are no longer available, hence the question. any assistance with a solution would be appreciated.
    because of the age of the car and the pipes, we fear that there could possibly be a leak and also would prefer to replace with new while the engine is bind re fitted into the sub frame.
    thanks
    Attached Thumbnails Attached Thumbnails Gs pallas-dscn4035.jpg   Gs pallas-dscn4036.jpg   Gs pallas-dscn4037.jpg
    16,748
    fuel line would do for that ... It would probably last the life of the car as it's internally re-enforced
    Sydney, Australia
    308
    Hi Lamoor,
    I just replaced a couple of those lines this weekend on my GS. The local Clark Rubber store has many different sizes of fuel line. If you cant get it from there the local Bursons store or Repco would have it.
    I didn't replace the lower two as I will leave that for when I have more access with the engine out. It would prove to be difficult in situ. (But not impossible)
    The tubes won't look the same, but they will be a hell of a lot more reliable. The old tube had split where it expands over the barb on the plastic tube. I suspect it was original.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    sydney-newport
    377
    Quote Originally Posted by XM Mechanic View Post
    Hi Lamoor,
    Hi XMM
    Thanks will look into this appreciate the advice, and yes it is easier with engine out.
