C5 wagon tailgate sag, roof leak, auto wipers
Results 1 to 7 of 7
Thread: C5 wagon tailgate sag, roof leak, auto wipers
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    571
    Default C5 wagon tailgate sag, roof leak, auto wipers
    My 2003 C5 wagon has a very poor spring or gas strut for the rear tailgate lift. I park it on a slight incline (nose higher) and the bloody tailgate will not stay open more than halfway. I have cracked my head on it that many times that if I don't get it fixed i will one day rip the @#&^#(*! off it's hinges.
    Does anyone have a quick easy and cheap solution to the problem?
    Also it seems to have developed a leak in the roof, probably the sunroof and is dripping into the load bay. I can't see any obvious places around the sunroof gutter where it might be happening. Once as again does anyone have a quick easy and cheap solution to the problem?
    What is it with the auto wipers. They are bonkers. I don't know why any manufacturer bothered with these as they have a mind of their own. Intermittent, or even better variable speed intermittent is far better. At least the auto headlights are reasonably sane.
    Any comments or tips are most welcome. cheers Tony
    8,257
    Quote Originally Posted by deesse View Post
    Hi Tony,
    Have a look through this thread. . .
    C5 Series one wagon - replacing rear door struts?
    08 C5 X7 HDi very Noir
    Mar 2011
    Linton.Victoria.
    1,282
    Guy I know rebuilds/repaires i.e fixes them-His number disappeared with my last phone-Will dig him up sometime tomorrow if time permits.
    OTHER WAY IS TO WACK ON AN OLD BIKE HELMET!
    Murwillumbah
    384
    My 02 wagon does the same thing with the tailgate, hopeless in the morning but ok when it's warmed up a bit. I just keep a length of curtain rod in the back to use as a prop as I figured the amount of work involved in getting the things out to have them regassed was not worth the hassle. Roof leak I can't help you with, auto wipers I just laugh at as a crazy f*****g french thing. cheers Dave
    San Diego, California, USA
    3,543
    Matter of fact, I do have an exceedingly cheap solution for the bad lift cylinder. A piece of schedule 40 plastic pipe cut a couple of centimeters shorter than the full stroke of the cylinder rod. Detach the lift cylinder, slip the pipe over the cylinder, then reattach. Make sure that the cylinder body rests on the pipe when you lift the gate. When you want to shut the gate, just lift the gate and this will release the load on the pipe, allowing you to slip the pipe back over the cylinder and drop the gate. This will solve the problem until you actually do replace the cylinder- which should be ASAP.
    Mar 2011
    Linton.Victoria.
    1,282
    David Sheridan Leo St. Fawkner. Ph.9357 2999.
    Dec 2010
    Melbourne Australia
    571
    thanks guys. It seems like the sensible option will be to dig out an old length of broom stick from the shed and cut it to the required length. I might then paint it LHS green so it looks factory!
    cheers Tony
