SOLEX 34PBIC adjustment
Results 1 to 25 of 49
Thread: SOLEX 34PBIC adjustment
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    Default SOLEX 34PBIC adjustment
    Hello, I forgot to mention. I also played with carburettor. I turned 2 screws one I think for the amount of petrol and the other one is idle speed.
    Is the anyone who can tell me how to adjust this thing? Or do you have specific manual for this? Now I have stuffed it up so I am thinking to buy repair kit to replace all the gasket. But I need to know how to adjust.
    Please help.
    Thank you.
    1,475
    I didn't know your car was still running as I thought you'd snapped the timing chain.
    You might find some useful information here:
    http://abarth-e-co.wikispaces.com/fi...+%2B+B+D-I.pdf
    1972 SM
    1989 BX 16 Valve
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    I went to the Manuals "sticky"
    Looked at the last post.
    Clicked on the link, read the page, looked for the appropriate manual (472 ID19) and......
    https://www.dropbox.com/sh/txhoyw2gqvc8lau/LnhQmqmhRh
    Now, look at plate 26 and operation ID142-1 work on the carburettor Solex 34 PBIC
    All in English.
    Hope this helps.
    DOWNLOAD the manual, save it to your hard drive, it will be there forever!
    Alternately, I have a factory manual for sale, on paper, the original thing! Find my post on Manuals For Sale.
    May 2011
    SOUTH MORANG
    793
    Quote Originally Posted by donat View Post
    Thanks for the link but I saw this already nothing about adjusting......
    No I have not snapped chain yet.
    May 2011
    SOUTH MORANG
    793
    Quote Originally Posted by richo View Post
    All in English.
    Hope this helps.
    Thanks Richo I have factory manual. It is not detail though... It is just saying turn (29) until motor run smoothly. And I can see the chart with many numbers for particular adjustment. What does those number mean?
    16,749
    There's is only one adjustment on the carby itself from memory. Idle mixture adjustment. The other screw your looking at is idle speed, it's just adjusting the stop point of the accelerator spindal (have a look, and you'll see what I mean). I just set them by ear... So it idles evenly, but doesn't lean out at low throttle settings.
    worn throttle spindals, and warped carby bases may make adjustment "interesting".
    seeya
    Jan 2006
    1,448
    Quote Originally Posted by caparobertsan View Post
    The factory manual and Shane are correct, simple adjustment only. There's no other detail. Follow the instructions and you should have a result, provided the carby is clean with no obstructions.
    Of course, as Shane suggests, if the throttle spindle or body is worn and the base warped, then those issues require attention to achieve a working result.
    May 2011
    SOUTH MORANG
    793
    seeya
    Thanks Shane. That sound easy. But Question is ....Should I pull it out and overhaul it or NOT. Car is running fine. Because I touched It is not starting like before( One crank would start engine strait away! like a modern car.). I enjoyed overhauling height corrector so I am thinking that would a fun. But there are many brass bolts around I can see... I wonder there are adjustment for them...??
    May 2011
    SOUTH MORANG
    793
    Thanks Richo I will do my best . Will overhauling of Carby benefit or increase HP/efficiency and response of ID19 motor?
    Jan 2006
    1,448
    Not to any degree you are likely to notice. Slightly improved fuel economy, depends on the condition of the unit now.
    Nov 2002
    Yarrabilba, Queensland
    2,759
    If after fiddling with that screw, it won't run very well. With the engine off, try turning the screw all the way in lightly, then back out about 1&1/2 turns. This is usually a good static point to start from for an idle mixture.
    When you have it set to that and you can get it running, if it is running OK, try sliding a piece of paper over the top of the carby..if you get close to 60% or so, and then it starts to stall, the mixture is pretty close to perfect.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    May 2011
    SOUTH MORANG
    793
    Quote Originally Posted by HONG KONG PUGGY View Post
    Hello, Thanks for the tip. So you mean to remove the air intake Lpipe and put paper on to to black the air and cover the inatke about 60% and motor will stall?
    16,749
    if your messing with the carby.... look down the throat of it ... see the air jet you can unscrew there ... DON'T TOUCH IT ... IT WILL SNAP OFF .... This is obviously only if someone hasnt' already snapped it off for you
    May 2011
    SOUTH MORANG
    793
    So I can see the nozzle when I remove the L Pipe? I have never played with any car so this is my first Carby....
    1,475
    Kaz, I'd be curious to know what fuel economy you do get on your ID compared to mine.
    1972 SM
    1989 BX 16 Valve
    May 2011
    SOUTH MORANG
    793
    To be honest I don't know. Because fuel tank float is melted or sinking( I put empty loctite soft plastic bottle) not reading accurate. Original cork had sucked petrol and sank. I have not driven a lot as I am scared if something might blow up.
    But it is economical than my 3.2liter car. Does your car smell inside ? I mean does your clothing smell like car( petrol, exhaust fume, oil burning etc.....) I know there is a big gap around steering wheel shaft.
    1,475
    My fuel gauge isn't the most reliable either and that's why I keep a log on my iphone - I put how much I've put in to fill it and at what mileage. I average around 9-10l/100km. My car has that brake fluid/old plastic smell which isn't too off-putting. My clothes smell more like nicotine than anything else.
    1972 SM
    1989 BX 16 Valve
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    This soaking of the cork plagues Paris built tractions also. I soldered a British tin float onto the 11bl sender arm. this fix could also be possible on an ID.
    Cheers Gerry
    May 2011
    SOUTH MORANG
    793
    YES nicotine smell that`s what I get too. So I guess it is normal. I need to put more tape and insulation pads top block the air entering inside car.
    May 2011
    SOUTH MORANG
    793
    Thanks. I am not in any harry but I am looking for the replacement of float. Yes tin sounds like better choice. Actually I might make one. Thanks
    Perth Western Australia
    2,705
    With my Peugeot cap on, adjust butterfly idle screw until the idle speed rises slightly. Now screw out the idle mixture screw until the idle gets erratic. Now screw the idle mixture screw in until it almost stalls. Screw out slowly until a more even idle is achieved.
    Now re-adjust the butterfly screw until the recommended idle speed is achieved.
    The brass "screws" you see are idle, main and pump jet holders, leave them alone. The same applies to the emulsion tube/air jet holder in the throat of the carb. [Shane's post *13].
    Any bits and pieces required for your Solex 34PBIC are the same as most Peugeot. 403. 404 and early 504.
    3,166
    How then do you clean out the emulsion tube, if you do not remove the air correction jet? They accumulate rubbish in the base of the tube and this in turn affects the running mixture.
    Remove the air correction jet very carefully and then use a piece of welding wire or similar to extract the emulsion tube. While they are out check to see that the spray tower is rigid in its mount. It mounts to the base on a short brass tube. This can become loose and it has been known to rattle out and drop down into the choke tube. The car will not run in this condition. I know this because I was stuck on the top on Mount Dandenong at mid night and had to have my father in law come out and tow me home! I think he was more interested in the safety of his daughter!
    The other problem, if this is loose is that it will leak fuel and empty the float bowl while standing, and also affect the mixture while running.
    You would have to be very clumsy to break the emulsion tower. But there is always a ham-fisted somebody out there tinkering with cars.
    Cheers Gerry
    16,749
    I've NEVER not broken any I've tried to remove. The last one was barely touching it with my finger tip. I think the issue is they have already been overtightened in the past fracturing the small housing they sit in.
    I'd NEVER EVER try to remove one .... It almost a certainty you'll snap it off
    May 2011
    SOUTH MORANG
    793
    So you are saying do not remove any brass screws and parts? I guess I can just clean them up and blow it dry with pressurised air.
    2,705
    Hands up those who've experienced poor running from a dirty Solex emulsion tube? Mmmm, that's what I thought.
    Now hands up those who've broken or experienced a broken emulsion tube/ air bleed jet holder? Settle down now, don't rush me!
    I managed to "splint" a broken alloy emusion tube holder with a piece of Biro outer just to get me home. 12 months later....
