As always ... the usual.... CX's and there charging systems
Results 1 to 7 of 7
    16,757
    Default As always ... the usual.... CX's and there charging systems
    There simple .... basic ... so why don't they ever work
    I noticed a couple of weeks ago the charge light came on..... when I turned the car off um, that's a newie ... the light then went out when the ignition was turned on .... so I started the car and checked the voltage at the battery. 14.1volts.....Hmmm..... Got me buggered I left the car in a shed for a couple of weeks without thinking about it ..... Then I went to drive it a few days ago.................. Not a bloody cracker .... The dash lights wouldn't even come on I charged the battery up last yesterday and noticed the charge light was on again last night after I moved the car....hmmm.... I drove to work today.... charging perfectly, but the battery seemed down a bit ..... Yep, I'm a genius, that's why I didn't think of pulling the battery terminal while I was at work.... Sure enough, I went to leave work tonight and the battery was to flat to spin the starter
    On the plus side, my new jumper leads work a treat :
    http://www.ebay.com.au/itm/1200AMP-J...a1959f1&_uhb=1
    On the negative side ... my wife wasn't really impressed about having to load all the kids in the car and come out so I could jump start it .... "You told me last week you thought the battery was no good ... WHY DRIVE IT WITHOUT GETTING A NEW BATTERY" ............. Hee, hee.... I think I have killed the battery ... I'll chuck the ID19's battery in the boot just incase the battery won't hold a charge since being flattened like it was.
    Anyway, I got home, switched it off..... charge light straight on .... WTF ... turned the ignition on ... charge light off I was thinking I'd need to pull the ignition out as a contact in it has obviously died... Removing CX igntions is always fun. I pulled the exciter wire off the alternator, managing to touch it to earth..... Bugger it ... No doubt I've now blown a fuse .... Imagine my surprise when I found the fuses intact, and the battery charge light back to it's normal behavior
    So I moved the car around ... switch it off ........ bloody charge light is back on when I switch the igniton off ... which means the exiter is always live ..... which means I'll likely flatten the battery over 48hours ... dead flat ....
    So I pulled the exciter wire off and tested the voltage having given in thinking the ignition has to come out...... And found no voltage there ... So I checked the alternator side and found 12volts there.... GOT IT !!!!!
    Hows this:
    The exciter wire on the back of the alternator was ***just*** managing to touch the 12volt feed to the battery.... So with the car off, the battery was feeding the exciter .... this caused 12volts at the battery end of the circuit, and it earthed back through the igntion, so the charge light would illuminate. With the car running, or igntion switched on, both sides of the exciter circuit has 12volts, so the battery light would turn off (when it should have been on). Confusing or what ??
    12,283
    and you still wonder why Ang loves the pug
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Armidale
    2,606
    So there was no-one at work who could/would help you get started? Sad really...
    Alec
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,167
    Got to hand it to you! You are always devising new and interesting scenarios. That exciter lead is notorious for getting cooked hard by the engine temperature. You are going to renew it?
    Cheers Gerry
    16,757
    There was cars in the carpark..... There all computer nerds though .... and the cars all looked really new. I didn't want to go sticking jumper leads on any of them incase I fried something in there cars (yeah I know ... unlikely .... If there was an old car there I'd have jumped it in a heartbeat).
    Life is supposed to be interesting either way right Think how boring life would be if I had a hi-undi i30 like everyone else.
    San Diego, California, USA
    3,543
    Hows this:
    I'm not saying a word....
    3,167
    You Just Said Heaps!!!!!
    Cheers Gerry
