Citroen CX electric mirrors
    Feb 2013
    458
    Default Citroen CX electric mirrors
    Hi, I'm restoring a 2200 Pallas. I have fitted the mirror from my '78 donor car (elegant non electric damaged) screw fitting is exactly the same. The mirror only works in one plane of motion. Restored the switch as stuffed with years of dirt. I pulled out the mirror internals & it's operated by Strings! Obviously there is a gearbox & faulty solenoid yet it is a sealed unit? Anyone repaired one or has a working one for sale?
    Via the aussiefrogs App
    Feb 2013
    458
    Update: Is isn't a sealed unit only clipped together. The Solenoid return spring was far too soft. I sacrificed a couple of retractable pens, a found a stronger spring and cut it down. It now works perfectly The mirror internals (made in holland) were first used by BMW in 1972.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Thanks for the news. I am going to try and get the mirrors working on the Prestige. Now I know it is possible
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Feb 2013
    458
    Left hand mirror installation advice required. I sourced an old Jag Series III LH mirror (Chrome, black surround & electric) it's still 4 wires yet two motors whereas the original is one motor plus solenoid. Jag switch required yet rare as hens teeth & very expensive. So need a similar wiring setup (I don't want to use two separate rocker switches) Where does Citroen put the switch for the left hand mirror on a Series 1 Prestige?
    Oct 2003
    1,304
    On the passenger door, exactly the same as the drivers. At least that is what is there on mine.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Feb 2013
    458
    Quote Originally Posted by Greg C View Post
    Missed opportunity to make that convenient. How French. At least gives one a reason to lean over an attractive passenger, or start a argument over "can't read a map now can't adjust a mirror"
