Plurial sensodrive problems! Help
    Tadpole smatic's Avatar
    Oct 2005
    bacchus marsh
    18
    Icon9 Plurial sensodrive problems! Help
    I'm trying to help a friend with an emotionally disturbed sensodrive in his plurial. He took off and as it did its 1st to 2nd change, bad noised came from the gearbox, and it failed to proceed. he turned it off, and now it won't start. as i have a xsara, i must know lots about citroens, so he asked me for help. (he knows zero about cars). I googled and found heaps about resetting these beasts, and have followed the couple of slightly different proceedures, basically disconnect battery for 2 minutes (or more) reconnect, sit in car with everthing off and closed, foot on brake, ignition on and wait for the dash selector to read "n". I hear it clunking away until it stops, but the dash still reads "auto". where to from here. said friend is not in a position for a new gearbox as suggested by the dealer he purchased the car from new. Help!
    10,192
    Something inside has possibly broken. Likely failures are the input shaft bearing, the clutch release bearing, the pinion bearing, but also, one of the selectors has a rivet that can come apart and cause the gearbox to lock up. It may be more involved that you are hoping.
    Fellow Frogger! BallinaOB's Avatar
    Bathurst, Australia
    135
    Not a solution sorry, just some things to look for.
    Interesting that the motor will not start. Problems with the sensodrive I have come across normally have the car running but the gearbox not going into gear (or coming out of reverse). Are there any warning lights showing up? Have you been able to check for fault codes with a portable reader? Problems I had with my sensodrive were fixed when I repaired ABS wires which had been chewed by a rat. Are all the lights working around the car? (can be an electrical earth problem - esp if break switch not functional - will not start without a signal from a depressed break). No blown fuses?
    One of the two actuators may be out of alignment. Have seen a couple of videos on youtube on how to check and service these (on a SmartCar not a Citroen).
    All the best of luck.
    Anthony O'Brien
    2019 C4 Cactus
    2008 C5
    2007 C4
    2004 C5 Estate
    Previous
    2003 C5
    2004 C2 (now with youngest son)
    2006 C2 (now with eldest son)
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,124
    Pete, forgot to mention today that I have a Lexia jigger now and it seems to work.
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's) Grandma's Taxi
    1974 D Special Manual Sedan ("Moby Dick") Weekend Warrior
    2015 C4 Grand Picasso ("Pablo") Workhorse & Grandpa's Taxi
    1982 2CV6 ("Gaston") Seasoned Traveller
    1975 GS Pallas ("GiSelle") Bonsai CX
