Xsara steering shudder at 100km/ph help Please
Results 1 to 14 of 14
    77
    Default Xsara steering shudder at 100km/ph help Please
    ok so after the adventure of the Xsara with the clutch having been in and out approx 4 times since feb i have been having some steering issues
    at approximately 100km/ph while the foot is on the accelerator i get a wheel shudder in the left front wheel that is noticeable in the steering
    all 4 tires have been replaced in the last 3 days that has included the wheel balance and a steering alignment
    all felt well when i got the car back and started driving
    wasn't till about an hour later as i was leaving Sydney on way back to the gong that i noticed that the same shudder that i had been getting before the tires had been replaced was back
    today i noticed that the car is pulling to the left again which it wasn't doing on Friday night when the tired were first done
    could it be a) the bottom engine mount
    or b) the front left break pads playing up
    or c) something else completely
    12,283
    a wheel weight didn't fall off did it
    how bad is the pulling, it's not trying to steer you into a better car like a peugeot ???
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    77
    throught the reason PSA release the Pug model first was to work out all the bugs before they released the citroen with outh as many bugs?
    any way back to the car
    no its pulling desperately
    more that on friday night i could let go of the wheel and it would drive straight for a reasonable distance before starting to move over to the left
    where as today it does it almost as soon as i let go of the wheel
    12,283
    try turning it all the way to the right and then try it again and see if it still pulls left
    1 x 2018 3008
    Armidale
    2,606
    I am following this thread with interest, as I have a similar problem with my 605. Doesn't pull to one side, but gets the shakes at about 100 km/h. Yes it's got wheels without centres (which most places can't balance), but I have had them balanced in Tamworth, but it has never completely got rid of the shakes, and problem has persisted over different sets of tyres. Rotating front to back makes little difference. Had thought about getting new(er) wheels with centre holes, but suspect I should look for other causes first.
    Have noticed that the front end of the 605 is noisier over our rough gravel driveway than the Xantia & the 406 - so presume it's time to replace control arm bushes, ball joints etc. No problem going through rego, but wondering if worn suspension components might contribute to steering wheel shake at speed?
    Alec
    16,757
    Did you loosen the steering rack when you your messing about with the gearbox. Your obviously practiced now, why don't you whip the 'box back out and see if there is any fasteners that were missed
    The intermediate driveshaft bearing isn't loose is it ? Think about everything you touched when the car was in bits, what touched would effect geometry
    PS: 'Rambo, it is a poogoe, it just has funny tacky looking plastic chevrons rather than tacky plastic numbers on it.
    10,196
    There are all the usual things to check, but also have a look at the wishbone bushes and check the mountings for cracks.
    77
    gear box mount is still ok
    top engine mount is new (replaced at same time as the clutch in feb)
    bottom engine mount looks ok on the out side but may have gone soft on the inside
    steering column was not touched when removing the right drive shaft
    but the steering arms were touched (arms were unscrewed ratther than the steering ball joint for 4 of the 5 times it was removed)
    but i'm assuming that they were adjusted back to straight when the alignment was done
    wheels are non hole xsara mags
    but the tyre service was done at Tempe Tyres which are a mag wheel specialist so im assuming that they do balancing on non hole wheels
    will checl all the ball joints again (leaver arm, wishbone and steering)
    could a warped disk break cause this at all or would notice it sooner than 100km/ph?
    only reason i ask this is when i adjusted the air in the tires i noticed that the left wheel was warmer then the right
    77
    Quote Originally Posted by little ufo View Post
    that should be not pulling desperately
    77
    ok so once i got home this arvo took the front left wheel off
    spun the disk around and found it was rubbing at one spot
    so may have found my culprit
    77
    Quote Originally Posted by pugrambo View Post
    While im doing 100?
    12,283
    While im doing 100?
    not in a citroen, the thing will have a fanny fit
    while the car is stationary turn it full lock to the right then take it for a run and see if it still wants to pull to the left
    1 x 2018 3008
    Armidale
    2,606
    Does it shudder under brakes? If not, it can't be warped very much .
    Alec
    77
    Alec
    no its not shudderin under breaks so can rule that one out
    while i had the wheel off i tightened up the steering ball joint
    it wasn't shuddering as much today but still had the shudders over 100
