xantia V6 crunch time
Results 1 to 25 of 26
    NORTH PERTH W.A.
    853
    Icon8 xantia V6 crunch time
    Finally got the bi**h home now it is decision time do I save it or more accurately is it saveable
    The car drives just ie engages D and R but there is a nasty whining grumble from the auto .
    1.Is it worth trying to resurrect it as stands ie pull the access cover clean out and flush or is the pump in the auto terminal and how much can be achieved without removing the box and splitting it
    2. Pull the auto and rebuild myself as if I have the time
    3. pull the auto and install manual box
    4. wreck the car
    It pisses me off that everything has just been done
    front discs
    cam belt
    coolant hoses
    steering hoses
    sunroof motor
    exhaust
    tyres
    window cable
    etc
    etc
    11,299
    FWIW I'd either fix it myself with a manual transplant (huge job in detail) or sell it to someone who would. The rest of the car is great.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Armidale
    2,595
    She'll be right - just drain out all that blackened Dex III and refill it with nice clean Dex II - fixes all french autos .
    Alec
    16,748
    Alec
    Don't the 4hp20's die around 150->200,000 ..... as in dead ... worn out, not contamination like the old 4hp18's
    JBN
    JBN is online now
    1000+ Posts JBN's Avatar
    8,516
    If the autobox is a ZF, its certainly worth dropping the oil and filling with a Dexron II oil. On BX and Xantia ZF boxes, I've use Castrol Transmax M. Its cheap and readily available and its Dex II. On the 4 cylinder autos, your drop 2.4l each time you drain the gearbox and transaxle, out of a total of about 6.5l. Keep doing this until the colour of what you are dropping approaches the colour of new fluid.
    In your case, since the car is barely driveable, just go around the block once or twice and drop the oil. That gives the auto the chance to mix clean oil with the old oil still in the torque convertor. If you have a few spare glass jars, put a sample of each drop into a jar, number it 1 to ? and you will see how the colour changes from black to more reddish.
    The above exercise may not work as the gearbox may be too far gone. At least the experiment won't send you broke. Should the gearbox be stuffed, check with Martin Bray in SA to see if he has anything to offer. I think the easiest is to replace the box with another automatic box rather than find a manual box and add all the related paraphernalia.
    John
    10,192
    4HP20 is a ZF box, but it apparently sounds like the pump has eaten itself and an oil change can't fix that.
    You may get away with replacing the pump if that turns out to be the extent of the problem. As far as I am aware, the case has to be split to do that job. It also allows you to clean the pickup, which is probably blocked.
    NORTH PERTH W.A.
    853
    cheers and thanks for the advice.
    Yes David I think it must be the pump even though the box engages there is a constant loud whine when running in any gear signaling that the pump has flogged out possibly thru starvation .
    It is a time and emotion thing,
    the car is worth a grand max as a basket case and 3 grand as a goer,
    I think pulling the box and fixing is likely more than 2 grand , a manual conversion 1 grand in parts and less than a grand in labour then a unique car worth ?? none of it makes much financial sense but the manual conversion would be fun. meanwhile the car is ensconced in the new archie carpark amazing finish the paving one day car on it the next
    Mar 2011
    Linton.Victoria.
    1,280
    Hi-Dave Cavanagh has or had a good ZF auto in a V6 auto he is wrecking????????
    NORTH PERTH W.A.
    853
    Quote Originally Posted by pekay49 View Post
    HAVE ALREADY DISCUSSED IT WITH THEM SEEMS IT IS HIGH K'S AND HAS HAD COOLANT IN IT FROM EXCHANGER When I consider price plus transport
    Me thinks out of the frying pan and into the fire
    11,299
    Quote Originally Posted by ARCHRIVAL View Post
    NORTH PERTH W.A.
    853
    Default guess what ARCHIE has just found
    Well I hope it fits
    Attached Thumbnails Attached Thumbnails xantia V6 crunch time-manual-box.jpeg
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,350
    So you bought the kit off gum tree? Now that would be a nice xantia!!
    2017 Renault Koleos auto
    tweed heads
    1,544
    Speaking from experience make sure you get everything you need from the car the box came out of,before it goes to the crusher ,if it hasnt already.its not until you get into it that you discover all the little bits and peaces that make it come together ,dont forget to by pass the isolator switch from the auto selector ,otherwise it wont start seems like a good result ,are the drive shafts the same .pugs
    Armidale
    2,595
    Where are the gearstick, linkages, the clutch pedal, brake pedal (almost certainly different to the auto brake pedal) plus whatever connects pedal to the clutch (cable? hydraulics?)?
    As pugwash says, get every mounting bracket, screw, fitting etc that might possibly be relevant.
    Alec
    11,299
    Alec
    As someone said, best to have the donor car alongside!! God knows what odd things will need changing too.
    Either way, good luck. A manual V6 would be a nice car.
    Romsey, VIC
    2,350
    I don't think a manual v6 xantia was sold here so finding a Donner car will be impossible!
    10,192
    Quote Originally Posted by cav91 View Post
    Maybe, the odd kebab though?
    I gather that lot came from a Pug of some sort. A late 4 cylinder Xantia manual would very likely donate items like the pedal box and lever etc.. Is the clutch hydraulic? Most of the 4 cylinder cars had a cable clutch, but some of the late examples and the Turbo I think had hydraulic clutch operation. It may pay to pick the right kebab to begin with. You may want find it helpful to find the correct part numbers in Citroen Service for a generic manual V6 Xantia and then search for the same part number across all the Pug models in the equivalent Pug parts system.
    Romsey, VIC
    2,350
    That sounds the go. I believe the bits in the picture came from a 406 sv
    NORTH PERTH W.A.
    853
    the setup I have found includes shifter and drive shafts , don't know whether i will need the shafts no clutch but i think it is a hydraulic and I may have to get that from the UK but should not be a problem getting the gearbox from the UK was size customs courier etc and cost
    This box is in SA so courier is easy and cost cheap
    donor car is gone but informed it had only done 140k
    so the box should be sweet ,
    may still have it stripped and checked before installation
    Thanks for the reminder re inhibitor switch
    Romsey, VIC
    2,350
    My v6 has nearly 290 on it and my mates has over 290 Both boxes sounds and shift perfect! so I doubt the box will have any problems
    11,299
    You'd better keep close to French Connection and others for Xantia manual bits I'd suggest.
    Mar 2013
    86
    Sad, the Xantia I was familiar with never missed a beat. It was a 2.0 litre 8 V Auto. Can't believe people have problems with those autos. Purred like a french pussy and best auto I have ever driven including the 6 speed C5 I now drive. Got to 200,oooks no probs never used a drop of oil. I think I'd take my father's advice in your case, that being, no good pouring good money after bad. Good luck. Bugger when things like that happen. Reminds me of a Land Rover I once owned. Worse car ever. Vowed never to touch a British car ever again. Might go a brand new Jag BUT nothing else. That Rover turned me French forever!
    Oct 2003
    Hampton Park
    523
    My 350k hp20 box is fine
    My 220k hp20 just died
    Member Tristesse's Avatar
    98
    My Xantia VSX 1998 2L 8V's auto died suddenly in the middle of the road. Spent $5000 on a reconditioned auto replacement. Stupid decision, but it was a lovely car. Traded it on my current C5. I wanted a V6 Xantia for a long time. Won't happen now. Lovely car to drive. I'll never forget my first drive of a Xantia. Reminded me of being in a Chevy Impala. It felt huge and floaty.
    Oct 2003
    Hampton Park
    523
    Just bought another V6
    Is there any hope?
