Citroen DS/ID LHM (1967-1974) Two Piece Adjustable Suspension Spheres. AND...
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Default Citroen DS/ID LHM (1967-1974) Two Piece Adjustable Suspension Spheres. AND...
    These don't come on the market all that often.
    I've bought cores in from Europe to be reconditioned and rebuilt.They're very scarce over there as well.
    Those owners who have them fitted to their cars enjoy a superior ride, in the way Citroen intended.
    The later riveted spheres can't be changed, though are rebuildable, provided the dampers aren't damaged.
    But I digress.
    I have one set for sale of the adjustable type, with the dampers to suit your desired ride. Rebuilt by me of course.
    These are rebuildable and can have the ride changed to be firmer or softer.
    Supplied with sealing rings and an extra set of sealing caps. The caps fit the suspension cylinders as well.
    These are for outright sale, no exchange or core charge.
    Here's an image of the exact set for sale. $950 plus $47 postage
    UBER RARE Slip In Damper Sphere Set For Sale
    Have a look at these. They are factory. The only set I've ever seen.
    The stuff of myths. They were originally fitted only to the DS21 EFI BVH equipped cars.
    Over the years of course they've been discarded, owners and service people not knowing or realising how rare and now adaptable they are.
    The dampers can be changed easily, with a special tool which will be supplied to the purchaser. Dampers from any of the late model one piece welded spheres can be fitted if they are machined out of the sphere bodies.
    Dampers from the two piece riveted spheres can be fitted as well, any combination your heart desires.
    I will be supplying one set of dampers with the spheres which will give the original ride. The future ride is yours to decide.
    Make no mistake, this is the only set for sale on the planet. If you happen to own one of the original cars and you want the original spheres, then this is probably the only opportunity to make a move.
    If you ever fancied changing the ride characteristics and mucking about, then these are gold.
    Dampers from DS CX, BX or even Xantia will fit right in. No special torques to consider, no specialist tools other than the one supplied. It's the only thing welded spheres are good for when dead!
    They will come with six seals and a spare set of red sealing caps.
    There are a few people who know what these are and their rarity. Of course, the possibilities for their use are endless.
    Price is $1100 plus $47 postage.
    Here are the images.
    Should you require further information or simply want to buy them, please PM or email jackafrica@gmail.com for a prompt reply. I prefer to speak rather than type (particularly when answering questions) so phone numbers are handy. My phone is
    zero 49 zero zero 39634.
    Thanks for looking.
    richo
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    Then I must be extremely lucky because my DS21 EFI BVH has got a set
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
    Jan 2006
    1,448
    Still available, I have also received another set of cores from Europe so another set can be made available for outright sale.
    These spheres are not usually available for sale, anywhere. As usual too, I appreciate your support.
    Jan 2006
    1,448
    And another bump
