Brake Light Switch?
    Sep 2012
    54
    Default Brake Light Switch?
    I have just received a new brake light switch from the UK, however not knowing these cars well would appreciate if someone can let me know exactly where this is on a 2005 C5 HDI and how easy it is to replace.
    Thanks in advance for your sound advice.
    Richard
    Sydney, Australia
    308
    I believe that it lives in the passengers footwell just above where the tops of your toes would be.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    Sep 2012
    54
    Thanks Garth. I shall take a look when I get a chance this week.
    Mar 2005
    922
    Richard, Why have you found it necessary to replace the brake light switch ?
    My 2006 C5 HDI 6 speed has been throwing up some stability and traction control faults on the screen these last few days, so ... as David S often declares strange things can happen because of the switch ( that does more than turn on brake lights ).... what were the symptoms you had ?
    Sep 2012
    54
    Pretty much similar to what you are seeing. Engine management fault, loss of power, stability and traction faults, which after stopping, turning car off and pressing brake pedal a few times seems to clear. The error light stays but everything seems to work just fine with full power and all. Typically at some point later in the day the error message will clear totally and all will be good for a while, at least until it happens again.
    Richard
