CX colour and Mags?
Results 1 to 21 of 21
    Fellow Frogger! meinkiev's Avatar
    Aug 2011
    Kenya, Africa; Kiev, Ukraine, and Albury, NSW
    138
    Default CX colour and Mags?
    Can anyone tell me what is the name or number of colour on this CX?
    And does anyone know if there are any Mag wheels like this around?
    It looks pretty cool and I would like to copy it!
    1,475
    I believe this is Rouge Delage and those wheels are exclusive to the Turbo series. You'd have next to no chance of finding a set in Australia.
    1972 SM
    1989 BX 16 Valve
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Double Chevron must have a set that he removed to get 'proper' tyres for his CX Turbo II. These will only take TRX tyres which is good and bad. Don't put them on an ordinary CX though, does not look right.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Dec 2010
    the netherlands
    24
    colours and brochures:
    http://www.citroencx.eu/
    are you in Australia ?
    here in Europe you can find them easily. Not everyone prefers to drive these with TRX tyres (very $$$$$$). I still have a set for my T2, but after the winter will go 16 inch. modern rubber drives much better.
    Aug 2011
    138
    Thanks Donat and Greg. I will have to look for mags that look similar then for which I can use conventional tyres. I am in Europe for now.
    Can I get 16" that fit the CX? Do you just ask for 16" wheels that fit a CX? Shane
    1,475
    If you are looking for mag options, there's an Alfa alloy that fits. Look for Petpug, he has them on his CX (which was once mine).
    1972 SM
    1989 BX 16 Valve
    16,754
    My father chucked the 'T'urbo wheels from my car before he imported it from the UK ( Why would anyone pay HUGE $$$ for that TRX garbage is beyond me). The tires are all least $500 each if you can find them.
    You can get aftermarket alloys for it in Australia. The stud pattern is 5 x 98. You'll need to get the offset measure and make sure you have clearance in the rear wheel arches.
    Dec 2010
    the netherlands
    24
    Like Shane mentioned clearance in the rear wheel arches is the tricky thing !
    alfa 147-156 wheels are all over the place, easily found.
    15 inch steel (in either 6J or 6.5J) will be an easy mount, no changes needed but a set of bolts. that is what I have now with decent winter tyres.
    if you want 16 inch alloy, you have to really just try !
    I have a set that works, but is 6,5 J, with 205 tyres. I had different Alfa spoke alloy set in 7J that had no rear clearance.
    But I do have to grind something off in front, or use a spacer so it wonīt get stuck on the brake caliper....
    at least they are the same 5x98 and 58 mm centre hole.
    aftermarket stuff is often 5x100, so you need sliding bolts. Good luck !
    Do report you solution here.
    Oct 2011
    Toowoomba
    658
    Quote Originally Posted by donat View Post
    There are a lot of hydraulic frogs out there that fit this description...
    Member mork63ukCGAT's Avatar
    Jan 2006
    Hull UK
    75
    Mine has 17x8 wheels on it. There are alot of options available, you need not be limited to the 5x98 pcd I use 5x100 pcd with wobbly bolts. I did have to adjust the inner part of the rear arches(big hammer) and file the lip (back to plastic) intwo places on the rear spats to accommodate them. Another consideration is the hub shape of the wheel so it doesn't foul the front calipers.
    Jan 2006
    Hull UK
    75
    I also had a set of 17 x 8 inch Azev type A wheel machined from blanks in 1996 or so (because there wasn't very much aftermarket stuff for CX's back then) they were 1300 quid with tyres then. I replaced them with the current wheels back in 2009
    16,754
    Quote Originally Posted by mork63ukCGAT View Post
    I much prefer these wheels. Do you just put on whatever set takes your fancy these days ?
    Jan 2006
    Hull UK
    75
    Nah, the Azevs went in the bin after aquiring a buckle that wouldn't straighten
    Fellow Frogger! Fingers's Avatar
    Old Junee NSW
    584
    Just didn't find the right wheel repairer
    Jan 2006
    Hull UK
    75
    Quote Originally Posted by Fingers View Post
    Never looked too hard The Azevs were tired and I did fancy driving around on welded rims. Plus I liked the look of the current wheels they are Dotz Hanzo. They have a nice scupltured shape to them.
    http://www.dotz-wheels.co.uk/about/dotz-range#
    hit the 3d option on the Dotz Hanzo rim
    Aug 2011
    138
    Thanks for all the answers fellers, this will help a lot. If and when I get it finished I will post it. You all know what that means in terms of time!!
    Shane
    Member petpug's Avatar
    Hornsby, NSW
    34
    Alpha wheels are still there Donat and the CX is going very well - got a new interior and a lot of work under the bonnet (thanks Jason). Now added a DS21ie (non Pallas) to the stable. Cheers, petpugCX colour and Mags?-img_8340.jpg
    Member twistedeez's Avatar
    Mar 2011
    Byron Bay
    114
    I know of a set of original alloys in Northern NSW. Owner is willing to sell as they are just lying around. He went for the Alfa option because of the cost of tyre replacement. If anyone is interested PM and I'll give you his number.
    Out of the 1992 Saab 900 turbo and into
    1989 Citroen Bx 16v
    Aug 2011
    138
    Is this colour Rouge Delage or Rouge Florentin? And was Florentin a metallic colour or not? It looks metallic here but photos can be deceiving. according to the year and model 1986, Pallas EI Automatic, it probably should be Rouge Delage. Is this correct?
    Shane
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,252
    That looks like Rouge Delage with a lot of very artistic lighting, or at a very slim chance even with some fleck added during a respray. RD is a solid colour, not metallic, and it is a colour which can look quite flat in photography, hence I suspect the use of artistic lighting. RD is most often seen in Australia on 2CV Charlestons. The photos appear closest to RD in the area around the rear numberplate, the sides look far too reflective.
    The red CX25GTi that was advertised for so long (last year/ earlier this year - I've forgotten) in NSW is Rouge Delage.
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    Aug 2011
    138
    Hello Bruce,
    thanks for your thoughts. I think you may be right. It's a really nice colour. My CX is white and for the moment I will leave it. It is a bit tired looking though and I am not fond of white and may change it to this. A white car seems more like a refrigerator to me!
    Shane
